Old 01-29-2011, 01:18 PM   #1
gibbons
Converting a 9 inch to disc brakes???
I have been jumping around this site for awhile now and realize there is some serious talent on here. Guys if you could i am in the middle of a 48 AD truck restoration and have a ford 9'' that needs to be converted over to disc brakes. If you know of a way that it can be done using doner parts it would be much appreciated.
gibbons is offline   Reply With Quote
Old 01-29-2011, 03:04 PM   #2
pgf545
pgf545's Avatar
Re: Converting a 9 inch to disc brakes???
I am not sure about donor parts but we went with the Wilwood setup. I think I have some pictures on my build thread. You might look into something like a Mercury Zephyr I think they had disc brakes but I am not sure if it was 9 inch or something smaller. Maybe a truck? Mustang? T-Bird? I am not very familiar with the factory setups.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 01-29-2011, 06:02 PM   #3
cap n crunch
cap n crunch's Avatar
If you want donor parts you could use Lincoln Versailles parts they had a 9" with factory disc brakes
ONE PIECE AT A TIME
http://67-72chevytrucks.com/vboard/s...d.php?t=442320 My Build Thread
cap n crunch is offline   Reply With Quote
Old 01-29-2011, 06:09 PM   #4
fishingjred73
fishingjred73's Avatar
I was told if you have the big axle bearing housing then the set up off of a 99-04 explorer will fit. There is a spacer that has to be made or bought though. And I think Currie has it.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 01-29-2011, 07:40 PM   #5
gibbons
hey thanks for the feedback. Now i just need to look into exactly what size the bearing is in mine. I just picked this truck up and it came with the nine inch. I've got a 8.8 out of an explorer and was thinking about just putting it in but ive always heard good things about the nine inch rear.
Old 01-29-2011, 11:43 PM   #6
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Unless you are making serious HP and torque 8.8 is the way to go. A lot of the explorer rears are posi 3.73 geared and have the discs you want already. It is gonna be a grand or better to duplicate that in a nine inch unless you are real lucky at the junkyard. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 01-30-2011, 01:25 AM   #7
gibbons
yeah i dont have a problem with the 8.8!! I need to do some measuring to see how it will fit. Have you guys heard any problems with the offset of the 8.8. It is offset 4 inches to the right and i worry that will cause some issues later like bad vibrations. I really wish i could just put the 8.8 disc brakes on the 9 but i have heard yes it works and no it doesn't. Is it hard to narrow the 8.8?
Old 01-30-2011, 05:43 PM   #8
nebdrummer
nebdrummer's Avatar
http://www.speedwaymotors.com/9-Inch...-Kit,5336.html
bolt on kits, with and without E-brake.
ive used 3 of these kits already, one for an 80 vette, one for a 67 nova, and my pickup... easy to install, and everything is new. cant beat it IMO
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 01-30-2011, 05:45 PM   #9
nebdrummer
nebdrummer's Avatar
and also, about the 8.8... i made one fit in a 51 ford pickup. it did not need narrowed, so i also was stuck with the offset. just make sure you do your measuring with your pinion angles. aka, if your trans is sitting at -2*, then your pinion should be +2*. there was no bad vibrations with it when i was done.
it will be just as easy or hard to narrot the 8.8 as it would the 9". you could probably get away with cutting off just one side, but im not sure if you can respline the stock axle or not.
Old 01-30-2011, 06:04 PM   #10
63chevyll
gets board easy.......
63chevyll's Avatar
i had whats called "big bearing ends" from mark williams i think. they were welded on mine when i narrowed it and ran all factory explorer stuff and drilled the rotors to fit GM car
63chevyll is offline   Reply With Quote
Old 01-30-2011, 11:55 PM   #11
jw4580
jw4580's Avatar
The explorer stuff will work if you have the big bearing ends on your 9 in. I dont know of anything cheap that will fit on the small ends.
jw4580 is offline   Reply With Quote
