Hi, new to game of rebuilding a Blazer. How do i find out what gears are in the front of my 71 blazer without opening it? The guy i bought from said the rear had been changed. Thanks
Re: Gears ?
Unless some previous owner took it off and tossed it, there should be a metal tag on the front diff underneath two of the cover bolts showing what the front ratio is. Usually it is covered in grease, so spray around the cover with carb cleaner and a brush. If it is missing, this would be a good opportunity to change the fluid in the front. Was the rear rebuilt or was the ratio changed? Either way, I would want to know for sure. I have a K30 with a Dana 60 front that the tag is gone off of. The front driveshaft was out when I got the truck, and someone has drawn a line through the 3.73 on the SPID and written in 4.10. All of these things are red flags to me, so both covers are going to have to come off to figure out exactly what some PO has jacked with.
#3 | |
Future TOTM Winner
Re: Gears ?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Re: Gears ?
If it came with a 350, it came with 3.07 gears. If it came with a 6 cyl. or a 307, it came with 3.73 gears. Any other ratio would be listed on the SPID.
Tim |
Re: Gears ?
My blazer with a 350 came with 3.73 gears. If he changed the gearing in the back and not the front he would've blown his t-case right?
Re: Gears ?
My blazer with a 350 came with 3.73 gears. If he changed the gearing in the back and not the front he would've blown his t-case right? I hope not!!
Re: Gears ?
__________________ Tim Thanks! |
