Old 07-02-2003, 01:05 PM   #1
messed up c-10
RHCP afficianado
messed up c-10's Avatar
stock rear end gears
Were the gears all the same no matter what engine or trans. combo a truck came with?
~Ryan~
89 S-10 Blazer with a 4.3L
96 Ford Crown Vic P71 4.6L V8. This car rocks.
Here are some links to some good music.
Jack Johnson
Donavon Frankenreiter
messed up c-10 is offline   Reply With Quote
Old 07-02-2003, 01:08 PM   #2
Prerunner1982
Prerunner1982's Avatar
no, but apparently from what i have seen the most common were the 3.08s atleast in the late 70s-80s trucks...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 07-02-2003, 01:16 PM   #3
messed up c-10
RHCP afficianado
Anyone know what an 84 with a 250 inline six and a four speed would have had in it?
~Ryan~
Jack Johnson
Old 07-02-2003, 01:22 PM   #4
gldevall
gldevall's Avatar
I've got an 86 and it had the 4.3 V6 with 400 TH and I have 2.73's.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 07-02-2003, 01:29 PM   #5
messed up c-10
RHCP afficianado
Did C-10s and K-10s have the same rear axle? If so I might have some low gears. http://www.chuckschevytruckpages.com/73-87specs.html Down at the bottom it lists Axle Ratios for K10s.
~Ryan~
Jack Johnson
Old 07-02-2003, 04:45 PM   #6
messed up c-10
RHCP afficianado
Now I'm confused. The RPO codes I got off of one site doesn't list my rear axle but Mike's site does and it says that I have
GQ1: REAR AXLE - STANDARD
does that mean I have 2.73's? If I have 2.73's then my truck must have gotten very good mileage with an I-6 and 700-R4. Also for my orginal trans. one site said 700-R4 and Mike's said
MX0: MERCHANDISING OPTION ONLY-DO NOT CATALOG
Anyone know a good way to see what kind of gears you have without having to take off the differential cover?
~Ryan~
Jack Johnson
Old 07-02-2003, 05:55 PM   #7
SCOTI
SCOTI's Avatar
The earlier 67-72's w/6cyl usually needed a little more gear to get them going (as do most smaller displacement vehicles). Both of the 6cyl's I own came w/3.73's.
Of course things changed in 73, but I would still guess 6cyl's came w/@ least 3.42's.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-02-2003, 07:08 PM   #8
Prerunner1982
gq1 i believe is the 3.07s or 3.08s atleast thats what mine says i have.
Jon
Oklahoma Roll Call
Old 07-02-2003, 09:10 PM   #9
83C
83C's Avatar
My truck came from factory with a I-6 and a 4-speed with the GQ1 rearend. I took the differential cover off and counted the teeth and it have 2.73 gears.
83 Chevy SWB
http://www.cardomain.com/id/letheridge
83C is offline   Reply With Quote
Old 07-02-2003, 09:23 PM   #10
Prerunner1982
ok i am stupid. hence the user text!
Jon
Oklahoma Roll Call
Old 07-02-2003, 09:31 PM   #11
SCOTI
SCOTI's Avatar
Prerunner, I have some buddies here in DFW that are in a band called . . .... The VillageIdiots.
Check out their site @ IdiotsVillage.com
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-02-2003, 10:16 PM   #12
swervin ervin
You get what you pay for
swervin ervin's Avatar
GQ1 just means it's a non posi rear. G80 is for posi. Standard means what was standard for the year. It gets confusing sometimes.
Look on the front of the passenger side axle tube about 3 - 5 inches from the carrier. See if there is an RPO code stamped there. I'm pretty sure if there is a code, the first three letters will tell you what gear it came stock with. Let me know if you find a code and what the first three letters are. I also need to know what rear brakes you have. 11 x 2, or 11 x 2.75.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 07-02-2003, 10:16 PM   #13
gldevall
gldevall's Avatar
GU2 is 2.73
Old 07-02-2003, 10:21 PM   #14
gldevall
gldevall's Avatar
Found it.
RPO CODES (CHEVY). ... RATIO GM3 : AXLE REAR, 3.45 RATIO GM8 : AXLE REAR,... 2.56 RATIO GQ1 : AXLE, STD ... ENGINE, GAS, 6 CYL, 2.8L, 2BBL, V6, 60 DEG, TRUCK LR6 : ENGINE
Old 07-02-2003, 10:43 PM   #15
swervin ervin
Uhh, I don't know where you got this from, but our trucks never came with a 2.8 V6, and especially a 60 deg one.
My 85 was a GQ1, and it came with 2.73's, which are RPO code GU2. GQ1 only means non posi. Look at this sheet that was in the dash of my truck when I bought it.
http://www.73-87.com/photos/old/build_sheet.jpg
Old 07-02-2003, 10:56 PM   #16
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
I figured KIILew would have been in on this one by now, but GQ1 doesn't mean non posi or any specific axle ratio. It means "Standard Axle Ratio" which you can look up in a table for your GVW, your engine, your trans, and your body style (Long bed, short bed, blazer, etc.)
For this case, from my 84 Light Duty Chevy Trucks Preliminary Data Book, from the power teams chart on page 78: A 1984 C-10 with a 4900-5600 # GVW, the LE3 4.1l 6 cyl and the MM4 4-sp would have 2.73 gears as its GQ1 option. With the MM7 4-sp, it would have 3.08's. With a 6100# GVW and the MM4 it would have 3.08, and MM7 it would have 3.42.
In this case, MM7 is the 4 speed with overdrive and the MM4 is the 4 speed without.
Mind you all of these are C10's even with 4 different GVW's. The C20, K10, K20 etc. are all in different tables.
On the other hand, the optional axle ratios are fairly easy to decode. GU2 = 2.73, GU4 = 3.08, GU6 = 3.42, GT4 = 3.73, GT5 = 4.10, HC4 = 4.56. As long as you don't have the 'standard' ratio for your particular combo, you can pretty easily figure out what your truck had originally. If you do have the standard ratio, you need a little more information and a table corresponding to your year to figure it out.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 07-02-2003, 11:36 PM   #17
swervin ervin
Thanks for clearing the GQ1 thing up. I stand corrected.
Mike
1985 Chevy C-10
Old 07-03-2003, 12:35 AM   #18
messed up c-10
RHCP afficianado
ok guys heres my RPO sheet.
~Ryan~
Jack Johnson
Old 07-03-2003, 01:11 AM   #19
TIMSPEED
TIMSPEED's Avatar
Hmm..how would I figure out what mine came with? I THINK they're 4.10's (from RPM). But how can I be sure? I didn't see ANY markings on the passenger side axle tube. I DID see some #'s on the actual carrier. Like, #389xxx..
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 07-03-2003, 01:19 AM   #20
ElGracho
ElGracho's Avatar
With MX0 and LE3 in an 84 C10, your truck originally had 3.08 gears with the GQ1 code.
Joe
Old 07-03-2003, 12:21 PM   #21
gldevall
gldevall's Avatar
Guess I should have read it better before I posted it. I found that through searching on Yahoo. Must have been out of an S-10.
