Old 02-01-2011, 02:20 PM   #1
Patriot
Question Pictures of K5s and Shortboxes with 1 Ton axles??
Do you guys have any pictures of K5s and/or Shortbox trucks with 1 Ton axlesunder them. I don't know what truck to use my axles under. Thanks fellas again.
Patriot
Patriot is offline   Reply With Quote
Old 02-01-2011, 05:13 PM   #2
79bonanza
Re: Pictures of K5s and Shortboxes with 1 Ton axles??
putting one tons under a truck wont make a diffrence in anything really, youll just have 8 lug wheels. i dont think you will gain any heights off a one ton axle swap
79bonanza is offline   Reply With Quote
Old 02-01-2011, 05:38 PM   #3
Patriot
Talking Re: Pictures of K5s and Shortboxes with 1 Ton axles??
But I will gain strength. I will need it for the Black Hills.
Old 02-01-2011, 05:42 PM   #4
russgt
russgt's Avatar
This is my 77 shortbox with a dana 60, Nothing too major vs a 44. Make sure to use a steering box brace because the frames on the K5 and shorty are thinner than the 1 tons, and man is it a heavy axle! Has dually hubs in the photos that have since been cut down
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 02-01-2011, 05:47 PM   #5
Patriot
I have been following your progress. VERY NICE work Russ!!!!!
Old 02-01-2011, 05:50 PM   #6
79bonanza
yea youll gain alot of strength but the only thing that could change would be how wide the axles are if you happen to get a dually front axle and a van rear 14 bolt.
Old 02-01-2011, 05:55 PM   #7
Patriot
Negative Ghost Rider. The donor truck is a 1980 3+3 SRW 1 Ton. Dana 60 front, Corp 14 Bolt(10.5 inch)
Old 02-01-2011, 06:11 PM   #8
79bonanza
hopefully the 14 bolt didnt come out of the dually as well
Old 02-01-2011, 06:59 PM   #9
Patriot
Just wondering why you keep trying to crap on my build?? FYI, it is an ALL ORIGINAL TRUCK that is still ALL TOGETHER. I will be taking it apart for my other toys. I have been building these trucks for over 25 years and have 14 of them. I know the difference between a DRW and SRW!!! Thanks for playing.
Old 02-01-2011, 07:15 PM   #10
russgt
russgt's Avatar
I think he was asking me that, No, the 14 bolt that I have is not out of a dually, If it was though, you would only have to swap hubs and move the perches, not the end of the world. The front DRW vs SRW difference is only the hubs, which is easily solved
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 02-01-2011, 07:22 PM   #11
Patriot
BINGO!!!
Old 02-01-2011, 07:24 PM   #12
79bonanza
calm down there killer, i was just making sure you werent goin to run into any unexpected axle fitment problems. but to each his own i guess, have fun with all that jazz.
just one question you said youve been building these trucks for 25 years and you want to see what one will look like with 1 tons under them. surly over your 25 year of your infinate wisdom building these trucks you would have seen one and noticed there is no diffrence.
Old 02-01-2011, 07:34 PM   #13
Patriot
WOW!! I guess the reason there such a site as this is for truck aficionado's to come together and share knowledge and PICTURES!!!!!!There are many men here who know a boatload more than I and have built some incredible machines. I just wanted to see a nice trail rig or show truck instead of the run of the mill mud trucks. I grew up with those all day long. As for difference, there is a HUGE difference in the swap. Many components to consider. Thanks for asking.
Old 02-01-2011, 07:51 PM   #14
russgt
russgt's Avatar
Its hard to reference a truck that you saw one time or use to own, its alot easier to look at a picture.
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 02-01-2011, 07:55 PM   #15
Patriot
Question Re: Pictures of K5s and Shortboxes with 1 Ton axles??
Hey Russ, are you putting 1 ton stuff under you K5?? I thought you had a 14 bolt with rear discs??
Patriot
Old 02-01-2011, 09:10 PM   #16
russgt
russgt's Avatar
yeah, I swapped the 60 out of the shortbox to put it in the blazer. I have 2 14 bolts that have disc brakes, but one has a posi and the other one is welded (PO).
Do you have a truck to swap the axles into yet or are you in the planning stages?
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 02-01-2011, 09:40 PM   #17
Squareforceone
Squareforceone's Avatar
good for you man
Squareforceone is offline   Reply With Quote
Old 02-01-2011, 10:20 PM   #18
Patriot
I have a 1980 Shortbox and a 4 Speed K5 Blazer like yours. I have a couple of 1 Tons and this one is one I will use as parts.
Old 02-01-2011, 11:46 PM   #19
f.monroe
f.monroe's Avatar
This one is on Ebay right now . I do not know whos truck it is but it looks reall nice with the heavy axles under it .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 02-01-2011, 11:53 PM   #20
Patriot
Frank
I like it. It almost looks like the front axle is forward just a little. Nice truck none the less.
Old 02-01-2011, 11:58 PM   #21
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
When I had my '79 K5, I swapped in a 14 bolt rear from a '79 3/4 ton truck and it was a direct bolt in. Only change was the drive shaft u-joint--I don't have the part number but it is sold at all the parts stores, and of course you'll need larger u-bolts.
For some great photos, head on over to ColoradoK5.com and almost everyone there has done this swap.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 02-02-2011, 01:16 AM   #22
N2TRUX
Happy to be here
N2TRUX's Avatar
... surly over your 25 year of your infinate wisdom building these trucks you would have seen one and noticed there is no diffrence.
What are you talking about? It appears to me he is considering putting one ton axles under a SWB truck or Blazer. There are a LOT of differences and advantages with a heaver axle, and it seems as if you know that.
Either offer some advice, or move along....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-02-2011, 12:01 PM   #23
bmchevy1979
bmchevy1979's Avatar
here is a few of K5s
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 02-02-2011, 12:07 PM   #24
Patriot
I really like the paintjob on the first one. looks pretty cool.
Old 02-02-2011, 01:41 PM   #25
bmchevy1979
besides the door not matching the paint it looks neat
<Brandon>
