line lock???
trying to get some info on brake line locks???
i got a 76 chevy 1-ton with 4 wheel disk brakes and no proportioning vale, how hard these line locks to install and would i need one for the front and back?? any info thanks |
Re: line lock???
What are you trying to accomplish with the line lock? Generally they are only used for drag racing and they would only lock the front brakes.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Re: line lock???
i was going to install line lock on my rear brakes to act as a parking brake. im guessing your thinking the same? cause i also have the one ton setup with 4 wheel disc brakes. line lock isnt hard to setup at all
Re: line lock???
what "Blue Chevy 1987" said. need it as a parking brake
Re: line lock???
yeah i need a parking brake.
Badass
Re: line lock???
all a line lock dus is you pump up pressure on the brakes and its a block off valve. hold pressure going to ether the front or back wheels.
what part if florida are you from
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90
On a budget like Fred Sanford
Re: line lock???
You can't use a line lock as a parking brake. You will burn up the solenoid and kill the battery in no time. They are designed to be used for very short periods only.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
Next!
![]() Join Date: Jan 2003
Re: line lock???
You need a mico lock like the bigger trucks have. I have one on my 86 K30 ex firetruck dump.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck Last edited by GM72K10; 02-02-2011 at 11:35 AM. |
Re: line lock???
I have a mechanical line lock in my 79 c30. It used to be a wrecker.. Works great as a e-brake
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
Re: line lock???
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. Last edited by spudz; 02-02-2011 at 11:42 AM. |
Re: line lock???
A guy I work for had a 79 1 ton bucket truck with a micro line lock . It was a 12 v system and was on the front brakes . It worked well as long as the truck was running but it did bleed off when left parked not running. It took us 3 hours to get it out off the woods after it bled off.
They do make a manual version that might work better.
69 gmc 4x4 lwb 327 4sd not running |
#12 | |
Conversion Truck Addicted
Re: line lock???
whats up with that turd floor matt
Thomas Quote:
Re: line lock???
how much is micro lock an where can i get it?
![]() Join Date: Apr 2009
Re: line lock???
#15 |
Re: line lock???
I use this one in my rock crawler and it works great as an emergency brake, $33.99
http://www.polyperformance.com/shop/...Lock-p-74.html Posted via Mobile Device |
#16 |
Next!
Re: line lock???
Its actually "MICO" lock but it seems like "Micro" is close enough.
http://cgi.ebay.com/ebaymotors/Mico-...mZ190477910719 http://cgi.ebay.com/ebaymotors/Micro...item1e61496e83
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
#17 |
Re: line lock???
You musta not read what I posted after the pic lol
| Bookmarks |
