Old 02-02-2011, 09:57 PM   #526
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
On the tcc i have it only locking up in 4th gear. It has no vaccum switch or any factory stuff. Just power, switch, solinoid, and 4th gear psi sensor. That is what i figured. I will get a tach soon and see what rpm it is really doing when it hits lockup.
I also am happy with exhaust for now. Still little anyouing but it is not as bad as it was.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-02-2011, 09:59 PM   #527
85burb
85burb's Avatar
Oh ya. I will getting wideband soon i think. I can only run one but if i do everything even the other side should be close.
Thanks yall for your info and input.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2011, 12:51 PM   #528
68 TT
Still plays with trucks
68 TT's Avatar
I used the Flowmaster mandrel bent tail pipes on my 81 K20 and they fit great.
http://www.summitracing.com/parts/FLO-15803/
The rest of the system I built with a few mandrel U-bends and some lengths of straight pipe and a pair of 50-series Flowmaster mufflers.
I had under $400 into the whole system and it looked, worked & sounded great.
I assembled it all in my parking space at my old apartment and used a rented oxy-acetylene welder to put it all together just like the muffler shops did before they got MIG welders. I even used a hand held jig saw to cut the tubing to size. No fancy chop saws needed.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-03-2011, 07:40 PM   #529
85burb
85burb's Avatar
Well figured i would get good breaks now that i have a good motor. Went out and got everything for the rears and rotors for the front. Have to take calipers off and match them up at store. Not looking forward to doing all this work. Also found water leak on my motor. Looks to be comming off of heater hose. Way to cold to fix it now. I am sure it seals up when it warms up. Also ordered all new brake cables for e brake so whiny babys dont give me crap about it this year during inspection time. Got cables from lmc.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2011, 07:50 PM   #530
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
ah.....see how it just starts to spiral into upgrading one thing or the other?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-03-2011, 08:14 PM   #531
85burb
85burb's Avatar
Also just ordered tach, few carb parts, trying to order dang uego thing buy summit is out of them. May have to find other store that sells them. I acctually blame you 68gmcustom cause you ordered 2. That second one was supposed to be mine.....JK
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2011, 09:50 PM   #532
yelo71454
Nice burban. You will be very happy with the ls powerplant.
Not to burst your buble, but my 84 burban 6.0\4l80e swap has been running since summer 2009. I beat you! Just kidding... Im from the panhandle, next time I drive down to the DFW we need to meet up and inspect burbans, meybe even race!
yelo71454 is offline   Reply With Quote
Old 02-03-2011, 10:31 PM   #533
68GMCCustom
Kurt -
Old 02-03-2011, 11:01 PM   #534
85burb
85burb's Avatar
WOW i got your first post. I feel specail. Your on for the race by that time it will be running rite. You have efi or carb?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2011, 11:01 PM   #535
85burb
85burb's Avatar
Originally Posted by 68GMCCustom View Post
I wanted two also.....Only have one o2 sensor bung.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2011, 11:27 PM   #536
85burb
85burb's Avatar
Well just put in my order for my uego. Cant wait tell it gets here....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2011, 11:41 PM   #537
yelo71454
fuel injected. I tried to make a project thread when I registered last year, but my username wouldnt let me post... I'll post some pics or make a build thread sometime in the next few days. Mine is a two wheel drive with longtubes and a custom tune.
Old 02-03-2011, 11:44 PM   #538
85burb
85burb's Avatar
I see. What headers did you use?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-04-2011, 12:27 AM   #539
yelo71454
I used fbody headers. I picked some ceramic pacesetters for 100$! had to hammer a dent or two to clear the control arms, but overall they fit sweet. the driver side collector comes close to the frame rail, but the exhaust guy did had no problem getting it to work.
Old 02-04-2011, 12:45 AM   #540
85burb
85burb's Avatar
I tryed dang fbody headers for the longest time. No way to make them work on my 4x4. BRPhotrods has a set of midlenghts that they have in a test truck that is 4x4 right now. If they work i will save my money to get some. Guy says on a 6.0 they added 38 rwhp. That is a bunch. But they are pricey too.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-04-2011, 01:45 PM   #541
85burb
85burb's Avatar
I guess i forgot to post final pic befor cleaning up wireing. Got to drive him in snow today. Loads of fun. That is all i have to say...fun
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-04-2011, 02:28 PM   #542
y5mgisi
Second Chance Program
y5mgisi's Avatar
Theres some pics finally! Looks sweet in there!!! Glad that you seem to be pretty happy with it.
y5mgisi is offline   Reply With Quote
Old 02-04-2011, 02:31 PM   #543
grayharville
^^who I am^^ what I say>
grayharville's Avatar
That looks damn good. Are you still in the Tyler area? P.S. I know of a very good exhaust shop that can fix you up right for a very good price. Every vehicle I have ever owned I have taken to him, and the work is always excellent, professionally welded, and exactly how I want it.
How are you liking the carb setup?
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 02-04-2011, 04:06 PM   #544
85burb
85burb's Avatar
Thanks. Yes still in tyler area. I am keeping this set up tell i get headers. If i ever get headers......smooth out of money. I like the carb set up. Motor does too i guess. Now if i could just tune the dang thing. But i have a little help coming in mail for that.....A wideband O2 sensor and gauge.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-04-2011, 04:07 PM   #545
85burb
85burb's Avatar
Yes really happy with it. Now to dial sucker in.........could take some doing there......
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-05-2011, 02:37 AM   #546
85burb
85burb's Avatar
So this is the timing curve i am thinking of starting with. If yall have any input let me know. I can have up to 6 dots to curve the line. The low side is 12 degrees the high is 32
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-05-2011, 03:14 AM   #547
MTCK
MTCK's Avatar
Can you adjust for load? My spark map looks like a spreadsheet with manifold pressure on the y axis and rpm on the x axis. Value in the cell is the advance.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 02-05-2011, 11:42 AM   #548
grayharville
I know what you mean about bein broke, it sucks! I like the idea of a modern motor with an old school carb setup, I bet that turns some heads for sure. what kind of MPG are you getting?
East Tx Squares
Old 02-05-2011, 11:56 AM   #549
kSStamp0182
LSX addict
kSStamp0182's Avatar
looks SICK man! hope to see it around. be careful out on these roads!! it seems like everyone wants to go slide around in their 2wd's. ive almost been hit countless times.
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration]
kSStamp0182 is offline   Reply With Quote
Old 02-05-2011, 01:06 PM   #550
85burb
85burb's Avatar
Yes it has a vaccum graph but it is in a unit of mesurment i dont under stand. DO you have one of these boxes?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
