Old 02-04-2011, 10:45 PM   #1
BigCarter
BigCarter's Avatar
Z'ing the frame on my 63 GMC
Hey guys maybe ya'll could help me out, i'm bagging my 63 GMC but i'm doing it on a budget and was wandering if anyone has z'ed their frame instead of buying a drop cross member for the front. Any help and pics would be greatly appreciate.
BigCarter is offline   Reply With Quote
Old 02-05-2011, 12:39 AM   #2
SCOTI
SCOTI's Avatar
Re: Z'ing the frame on my 63 GMC
Look into the suspension forum using the search feature. That should help get you multiple threads covering Z'd frames & get you ideas from different perspectives.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-05-2011, 12:44 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Welcome to the forum BigCarter. There are a lot of ways to lower your truck on a budget. Doing a Z would not be my first choice.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-06-2011, 09:40 PM   #4
BigCarter
BigCarter's Avatar
what would you recommend, also i scored an entire front crossmenber out of an 84 C-10 with drop spindles and lowering coils, i measured and the measurements are the same as my 63 GMC crossmenber, to tell you the tructh they look almost identical, do you think i can use the spindles and coils from the 84 to put on my 63 i talked to some guys and i've heard alot of different things, some say it wont fit and some say they bolt right in and some say they fit but you have to swap to ball joints off of the 84. Whats your thoughts.
Also thanks guys for ya'll help in this.
Old 02-07-2011, 12:06 AM   #5
SCOTI
SCOTI's Avatar
The 84 stuff will swap over to the 63. You can do parts only or the entire crossmember.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
