Old 02-04-2011, 12:44 PM   #1
72gmcshorty
72gmcshorty's Avatar
do i need this?
I plan on lowering the front with bags and drop spindle. Currently, my lower arms are missing this piece. Do i need them?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 02-04-2011, 01:08 PM   #2
71swb4x4
71swb4x4's Avatar
Re: do i need this?
No, it holds the bump stop. A lot of people run with no bump stop or they install a bump stop directly to the A-arm.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-04-2011, 01:12 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: do i need this?
Not really.
That's the steering stop for the spindle.
The long "slot" on top is for the rubber snubber,... that you no longer need.
Keith
Convert to disc brakes.
Old 02-04-2011, 02:26 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Re: do i need this?
...and would probably rub your bags...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-04-2011, 09:16 PM   #5
jugernot
Life, Be In It.....
jugernot's Avatar
Re: do i need this?
What would or have you done to remove them?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 02-04-2011, 10:23 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: do i need this?
They are spot welded on. You can use an air chisel to remove them.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-04-2011, 11:25 PM   #7
72chevy383
Re: do i need this?
Would you need to remove that pc with 2.5 drop spindles and 1 or 2 " drop coils? Or would you be ok and not rub?
72chevy383 is offline   Reply With Quote
