Old 01-29-2011, 08:40 PM   #1
orange prostreet69
clutch linkage
Anyone have pics of their clutch linkages at the frame and engine block? I have a V8 350 and the block appears to have two seperate holes for the ball stud to go in. I dont know which one to screw it in. Either one of them causes the z-bar of the linkage to go at an angle where it mount to the frame. Any help would be great! Thanks!
'69 SWB, 396BBC, M21-4 speed
orange prostreet69 is offline   Reply With Quote
Old 01-29-2011, 08:57 PM   #2
sjarrett71
sjarrett71's Avatar
Re: clutch linkage
I can get some in the morning but my truck was originally an auto trans and the people that put the standard in did a sloppy job.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 01-29-2011, 09:18 PM   #3
JimKshortstep4x4
Re: clutch linkage
Your application must need the ball stud that is mounted on a flat bar where the bar bolts to the block using the two holes.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-29-2011, 09:41 PM   #4
dadsworktruck
Re: clutch linkage
I found a couple pictures that might be helpful
dadsworktruck is offline   Reply With Quote
Old 01-29-2011, 09:53 PM   #5
Mt Man Chad
Mt Man Chad's Avatar
Re: clutch linkage
If ya need any of parts I'll be posting a complete setup tomorrow.
As well Tons of other parts, I need to make room for my next project
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 01-29-2011, 09:57 PM   #6
orange prostreet69
Re: clutch linkage
Are there any pictures of this flat bar that bolts to block for the ball stud application? Also does anyone know as to where I can find this flat bar so I can get my clutch linkage taken care of? Thanks Again guys for the info!
Old 01-29-2011, 11:36 PM   #7
glider_6969
Re: clutch linkage
does this help,, ( sorry a bit dirty under the hood right now). The first picture is what was on it when I put the motor in, had the flat bar and ball and didn't line up. I changed it and then had to modify and reweld the bottom arm of the Z-bar that goes to the clutch arm, or it would have hit the back exhaust header.
glider_6969 is offline   Reply With Quote
Old 01-30-2011, 11:51 AM   #8
sjarrett71
sjarrett71's Avatar
Re: clutch linkage
Here are the pics. I'm sorry for the quality but it's pretty cramped under there. I have a 350 with ram horn exhaust manifolds (as you can see).
Looks like you need that metal plate that the ball stud screw into. My z-bar is straight across.
-Scott-
Old 02-04-2011, 08:52 PM   #9
orange prostreet69
Re: clutch linkage
Where can I buy this flat bar for the ball?
Old 02-04-2011, 09:05 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Re: clutch linkage
sjarrett71:
In your pictures I think the stud on the outside of the frame bracket has flats on it that are supposed to line up with the notch in the bracket behind it. It should slide in there then tighten it up so it can't slide up and out of the bracket. You might want to check that out.
LockDoc
Leon
Old 02-04-2011, 11:00 PM   #11
sjarrett71
sjarrett71's Avatar
Re: clutch linkage
Thanks LockDoc. I've fixed it once before. When I got the truck it was extremely loose too. A PO put a manual in the truck so I can't really assume it was done right anyway.
-Scott-
Old 02-05-2011, 03:49 PM   #12
sjarrett71
sjarrett71's Avatar
Re: clutch linkage
Found a set on ebay.
http://cgi.ebay.com/ebaymotors/1967-...item1c190a4a78
-Scott-
