02-06-2011, 05:10 PM | #1 |
Crossmember
Anyone know where I can find a bolt in mustang II crossmember for a 67-72 chevy truck?
Posted via Mobile Device |
02-06-2011, 05:17 PM | #2 |
67-72 parts collector,…
Re: Crossmember
Fatman Fabrication sells them.
www.fatmanfab.com. Any certain reason you want a Mustang II front end? Just asking.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-06-2011 at 05:18 PM. |
02-06-2011, 05:30 PM | #3 |
Re: Crossmember
Yea I want the rack and I know there are other options out there but I have already spent the money on some nice spc adjustable control arms spindles and bigger crossdrilled/slotted rotors. Main reason is for front end weight reduction. Any ideas?
02-06-2011, 05:31 PM | #4 |
Re: Crossmember
Fatman fab says I can knock about 300lbs off the front of it. Idk how true that is
02-06-2011, 06:35 PM | #5 |
Re: Crossmember
SPC arms, spindles, & brakes for a MII?
02-06-2011, 06:38 PM | #6 |
Re: Crossmember
Spc control arms
02-06-2011, 06:40 PM | #7 |
Re: Crossmember
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-06-2011 at 06:49 PM. |
02-06-2011, 06:42 PM | #8 |
Re: Crossmember
Yes, it's a brand name. I've never heard of SPC arms working on a MII x-member though. I have them for my G-body Malibu (along w/a tall BJ conversion for a better camber curve)
02-06-2011, 07:37 PM | #9 |
Re: Crossmember
93010 (RH)
93000 (LH) Here are The part numbers straight from Spc for mustang II Posted via Mobile Device |
02-07-2011, 12:32 AM | #10 |
Re: Crossmember
Not calling you out or anything.... just never seen p/n's for the MII set-up.
02-07-2011, 12:48 AM | #11 |
A guy with a truck
Re: Crossmember
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-07-2011, 12:52 AM | #12 |
Re: Crossmember
Yea that's what I'm talking about just hope it all works when I'm done anyone know what a stock disc brake front end weighs compare to a mustang II?
