1972 truck bucket seats from blazer
What has to be done to 72 blazer seats to make fit in pickup. Are the blazer seats the same except for tracks and is there a difference in blazer and truck consoles.
Re: 1972 truck bucket seats from blazer
I believe that the seats are the same. The consoles are also the same. Driver's track the same. Passenger seat has fixed brackets in truck and flip brackets on the Blazer. Some Blazers had utility buckets in them and these are not the same as truck buckets. If I'm wrong on any of this, someone will correct me.
#3 | |
VA72C10
![]() Join Date: Mar 2008
![]() And the flip brackets can actually be cool on a truck...especially if you've relocated the gas tank....would give you an area behind the seat for storage that was easy to access. Or if you had stereo equipment you could get to it much better than if the seat was on fixed platform. If you're going for a stock build you'll need the correct brackets as well as the correct bracing underneath the cab. I was just made aware about the bracing. If you don't care about originality just be sure to add something extra to brace the buckets for safety.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#4 | |
Always on the hunt...
![]() Join Date: Sep 2006
#5 | |
Moderator
![]() Join Date: May 2007
![]() Quote:
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
