![]() Join Date: Mar 2004
Re: Project Lemon Drop: anything but stock!
Looks Great! Are your hood hinges anodized?
Life, Be In It.....
![]() Join Date: Oct 2003
No. They are painted the same color as the block. I had a set powder coated but the thickness of the coating prevented them from moving. So for that reason I could not use them.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
Eat, Sleep, Drive a Chevy
Man that stinks about not being able to use powdercoated hood hinges. I was thinking about getting mine done, I'm glad I could learn about this before hand. (thanks jugernot) I wonder if the powder coat guy would know that this would be an issue and warn a customer?
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
![]() Join Date: Feb 2011
Wow I was in the process of powder coating my hood hinges. So that's not a good idea? Or did they just coat yours too much?
http://67-72chevytrucks.com/vboard/s...ban+Retro:fro: |
just got my hinges back from the powder coater today and they work fine. I just pulled the springs off and had to break them loose again. Look and work great
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
Life, Be In It.....
I received some parts this week and may try figure where I should put them on the frame. I'm thinking of putting the tanks under the cab and the compressors just behind the tanks. I'm not sure where I'm going to put the air valves, maybe on one of the cross members. I may ditch the plastic line and go with hard lines.
Life, Be In It.....
I had a few hours to spare, so I went into the garage and mocked up the tank and compressor on the driver’s side. I made some templates so the passenger side install should go a bit quicker. I'm thinking of splitting the Big Red valve unit into two pieces, one on each side of the frame near the tank and compressor. I plan on running a line connecting the two tanks together, just in case one of the compressors fails.
67cheby
![]() Join Date: Sep 2008
very nice , very clean work
