Ridin' Dirty
Full Time 4x4 T-case, only turns front shaft!
I have a 1985 Chevy half ton thats been frankenstined by the previous owner, so I don't know what is stock and what isn't. What I do know is that the transfer case doesn't have a 2wd option. (Military?) Anyway, I tried to move the truck the other day and it wouldn't move when I put it in gear. I looked under the truck and saw the front shaft turning, but not the rear! So I locked the hubs, but it still wouldn't move. (I think one of my hubs isn't locking)
Is this a common problem/symptom? What's broken?
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
NOT REALLY BANNED!
![]() Join Date: Jul 2004
Re: Full Time 4x4 T-case, only turns front shaft!
If it's a full time transfer case (203) with manual front locking hubs and it doesn't have a part time conversion in it. Odds are something is burnt up.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
Not an expert but sounds like the rear output shaft or spider assembly broke. Was it running before? Can you turn the back drive shaft with the transfer in neutral pushing it (no power applied from the transmission). If the front shaft turns then the chain and that engagement is working somewhat. I suspect you will find the back drive line locked up as well.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 02-08-2011 at 09:43 PM. |
If it is a full time case (NP203), and you tried to move it with the front hubs unlocked, what you describe is exactly what would happen. The front shaft would spin and the truck would go nowhere. That is normal operation for a 203. An '85 would have come stock with an NP208 though.
Tim |
#5 | |
Ridin' Dirty
Thanks for all your input guys!
| Bookmarks |
| Tags |
| 1985, chevy, full time 4x4, t-case, transfer case |
