Old 02-06-2011, 05:20 AM   #1
mjo8585
mjo8585's Avatar
Wanting to slam my truck.. bag ?'s
hey I am starting a body off resto on my '68 C-10 and really want to lower it using air bags. I have no idea what the price rang is on a kit. Or what a good setup to go with. I also would like to c-notch it as well. Any help would be soo appreciated! This forum is freakin sweeet!
mjo8585 is offline   Reply With Quote
Old 02-06-2011, 06:05 AM   #2
ATrain707
Re: Wanting to slam my truck.. bag ?'s
it depends what u want to spend on a system, and there are different stages. heres a start i dont know too much. here are a few setups.
https://www.classicindustries.com/co...=1&sortOrder=1
here is a rear set up with c-notch
http://www.jegs.com/i/Ridetech/029/A...0LCAK/10002/-1
ATrain707 is offline   Reply With Quote
Old 02-06-2011, 05:17 PM   #3
colin_havens
colin_havens's Avatar
The biggest question is how low do you really want to go. A pretty simple system can be pieced together if you are looking at doing the minimal amount of cutting, but you will not lay frame when you have the bags fully deflated. If you want to lay the frame on the pavement, the diffuclty lever and cost greatly increase.
If you just want to just put bags in place of the springs and not remove fenderwells or cut the bed, you will need drop spindles, airbags, and bag plates and cups for the front. Simply bolting bags to your trailing arm and the frame in place of the springs in the rear will get the job done, with some drop blocks and a bolt in c-notch to get it as low as is possible in the rear without cutting the bed.
No matter what the air setup is, you will need an air tank, compressors, airline, fittings, and valves. that is if you want adjustibility in the cab. If you are doing it in stages, you can fun your airline to schrader valves, and air it up with the shop cmpressor until you can save for the rest of your air management.
There are alot of options out there, just be sure you use quality components in your system. After all, these parts are holding your truck up off the ground! I encoourage you to check with our board vendors to see what they have to offer, and make your decisions. Suicide Doors.com, Porterbuilt Streetrods, Scott's Hotrods, AVS, ect. I would spend alot of time in the suspension forum, as thats what I did before I redid my suspension to fully lay out. Good luck with it, and most of all HAVE FUN!
colin_havens is offline   Reply With Quote
Old 02-06-2011, 06:36 PM   #4
58 gmc
ToTM Winner
58 gmc's Avatar
Slam it
ToTM Winner
58 gmc is offline   Reply With Quote
Old 02-07-2011, 09:37 PM   #5
PGSigns
PGSigns's Avatar
I just went through the same thought process on what to do with my 65. What I decided on was to order 2 1/2" drop spindles, 2" blocks and u-bolts for the back and a basic bag kit with the schrader valves to get me started. Going to do the power disc brakes and power steering at the same time. Got most everything from vendors here for a great price. Once this part is complete I will upgrade the bag controls.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-09-2011, 07:02 AM   #6
mjo8585
mjo8585's Avatar
goodness! thanks all you guys for the great replies. this is really going to help me out in the comming months!!
Old 02-09-2011, 11:42 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Most of the information you will need has been covered in this forum extensively. Spend some time researching to determine how low you want to go. Set a realistic budget, and buy quality components as you can afford them.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-09-2011, 11:51 AM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Here's a really good thread, that shows some bagged 67-72 trucks,...
http://67-72chevytrucks.com/vboard/s...d.php?t=255929
Keith
Convert to disc brakes.
