Old 02-09-2011, 06:08 PM   #1
Reziel_1983
Reziel_1983's Avatar
Quadrajet making a whistling noise
Okay, so lemme explain what is happening.
I used to have an edelbrock 600 cfm carburetor on my 350. The 350 had headers, and edelbrock performer intake and a cam that was 3 steps above stock(I think).
We installed a bigger cam because my cam had a bad lobe and lifter so we just decided to upgrade to a bigger cam. With this new cam in and the edelbrock 600 cfm still on the engine we couldn't get the timing to be set. We could never get it to stop clattering, so we decided to try to put the old quadrajet back on. T
he timing on the engine is now set correctly but the carburetor is now making a whistling noise. We have had the quadrajet rebuilt before putting it back on. I'm a little new to engines and was wondering if anyone knows what might be wrong.
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD
1998 Trans am, mostly stock with magnaflow catback
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329
Reziel_1983 is offline   Reply With Quote
Old 02-09-2011, 06:23 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: Quadrajet making a whistling noise
Sounds like a vacuum leak to me. Check to see if there are any loose vac. lines or possibly an unused vac. port. Also, check if there is a good seal at the carb. base. Did you use a new base gasket?
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 02-09-2011, 06:46 PM   #3
Reziel_1983
Vac. lines are good I'm pretty sure... I'll recheck them once it warms up. I think we are going to get a new base gasket because we didn't get a new one, hopefully that'll fix it, thanks.
Old 02-09-2011, 06:54 PM   #4
Restrorob
The One And Only !!!
Restrorob's Avatar
Also check the primary and secondary throttle shafts for wear/play in the base, They can cause a whistle as well.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-09-2011, 07:33 PM   #5
JMac11
JMac11's Avatar
Make sure the choke is firmly seated to the throttle body.
JMac11 is offline   Reply With Quote
Old 02-09-2011, 11:03 PM   #6
sierra4x4
sierra4x4's Avatar
One time I had a whistle and it turned out to be where my air cleaner meets the carb. My air cleaner was hanging up on something and wasn`t fully seated on the carb.
sierra4x4 is offline   Reply With Quote
Old 02-10-2011, 12:13 AM   #7
jitteryguy
GoatLube Experss
jitteryguy's Avatar
look close at all the mount'n tabs on the carb when ya replace the gasket, I've seen em crack there and leak vacum (whistle) . if it is crack'd the Edlebrock 600 will run with that cam, it just may need a good clean'n.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 02-10-2011, 03:40 PM   #8
Malo83
Cruzzzn' Vet
Malo83's Avatar
Spray carb cleaner around the base of the carb and vac lines if the RPM changes when you spray an area, that is where your vac leak is
Malo83 is offline   Reply With Quote
Old 02-10-2011, 11:13 PM   #9
Reziel_1983
Thanks for the suggestions guys, I'll check all these on Saturday.
