02-09-2011, 07:55 PM | #1 |
Try spinnin 4 rear tars
aftermarket disc brakes & 15" wheels
I'm planning on a future swap to disc on the front of my '70. I will be staying with 6-lug and using an aftermarket kit. I'm also wanting to keep my stock dog-dish hubcaps.
I haven't found my stock steel wheels yet, and have recently read that the 15" wheels will not clear the calipers... The sticky says so I also read that the 73-87 16" 6-lug will work as the replacement. So, is all the above information true? I just found me a set of 16"wheels locally and want to make sure this is the route to take or to hunt some 15".
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
02-09-2011, 08:30 PM | #2 |
67-72 parts collector,…
Re: aftermarket disc brakes & 15" wheels
The 71-87 4x4 steel wheels (made for hubcaps) are 15"
They should work fine for your dog-dish hubcaps. They should also be cheap! The 88-98 6-lug wheels are 16". (I'm pretty sure they don't take a hubcap. Nothing to snap them onto) They are the correct 6-lug bolt pattern,... but I would be afraid that they are the wrong offset. (sucked in to far,... or too much backspacing)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-09-2011 at 08:31 PM. |
02-09-2011, 08:32 PM | #3 |
Also,... the only 15" oem 6-lug wheels that won't clear the disc brake caliper,... are the wheels made before the 1971 model year.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-09-2011 at 10:35 PM. |
02-09-2011, 09:10 PM | #4 |
Old Skool Club
I have ECE (Early Classic) 2.5/4.0 drop. When I did the drop, I had 15x8's all the way around. The same wheels, when reinstalled back on the front, stuck out past the outside edge of the fenders. So, I swapped the 8's for a pair of 7's, up front. Problem solved.
I wanted Wheel Vintiques vette-style rallye wheels, so I ordered a pair of 15x8's up front, with a 4-inch backspace. In the rear, they're 15x10's, with a 5-inch backspace. What won't work up front, are the original steel wheels for drum brakes. The backside of the wheel won't clear the brake caliper. If you convert to 5-lug, the '71-88 wheels will work (5 on 5-inch).
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
02-09-2011, 10:26 PM | #5 | |
vw guy & now c-10 guy
02-09-2011, 11:17 PM | #6 | |
Thank you all!
