67 c10: can i use 1/2 ton springs on a 3/4 ton lower a arm
Howdy,
67 1/2 ton c10 2wd frame is shortened, l6 292 not built yet, muncie 3 speed on the floor. I plan on doing one of 2 things either leaving the truck stock height and upgrading the front to 88-98 spindles brakes etc, or getting the 88-98 lift spindles. Either way my right coils are both cracked, so before i reattach the cab frame mounts and cab i need to replace my coil springs in the truck. I will do the springs so i can make a decision on the lift. I want lift but dont need tons, in a different thread the formula for using these lift spindles are to use 3/4 ton lower a's and 3/4 ton springs. They also use 88 ball joints and inner and outer tie rods. Is there any reason i cant use all 1/2 ton springs? Is there a reason i shouldnt go progressive? I would like to not have a ride like a lumber wagon. Ed FortyTwo |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 67 c10: can i use 1/2 ton springs on a 3/4 ton lower a arm
The 1/2 ton spring will physically fit in the spring pocket.
I don't see why you couldn't use any 1/2 ton spring.
