Old 02-10-2011, 02:09 AM   #26
muthstryker
muthstryker's Avatar
Re: Front rally wheel clearence issue, need help..
So I would be completely fine with those ralleys? As far as fitment goes?
muthstryker is offline   Reply With Quote
Old 02-10-2011, 08:38 AM   #27
lolife99
67-72 parts collector,…
lolife99's Avatar
The wheels in the pic from the Craigslist ad look like 15x7's on the left and 15x6.5's on the right.
I would try to find a set of 15x8's for the rear.
15x6.5 (4" BS)
15x7 (3-5/8" BS)
15x8 (4" BS)
What is the backspace of your wheels?
Keith
Convert to disc brakes.
Old 02-10-2011, 02:24 PM   #28
muthstryker
15x6.5 (4" BS)
15x7 (3-5/8" BS)
15x8 (4" BS)
Honestly, I dont even know of the backspacing on them. Never even checked if its nice out this weekend I will pull one off and find out.
Old 02-10-2011, 03:02 PM   #29
lolife99
lolife99's Avatar
Have you done any trimming on the lower a-arms?
With minor trimming any 4" backspaced 15" wheel will work with 2.5" or 3" drop spindles.
I suspect your 88-98 wheels have more than 4" of backspacing.
Keith
Old 02-10-2011, 04:54 PM   #30
muthstryker
My interference isnt on the control arms, its where the steering arm connects to the spindle. I will snap some pictures this weekend and post them up so you can see. Ive ground down as much as I feel comfortable doing on that section of the spindle. Its really really miner where it is rubbing, not much is contacting the wheel.
I was looking at it last night and was almost thinking a small 6-7 mm spacer would be enough. That would still even give me enough hub so the truck wouldnt be "held" up by the wheel studs.
Old 02-10-2011, 04:54 PM   #31
SCOTI
SCOTI's Avatar
I recall the 88-98 steelies having 4.25"bs but don't have one handy for verification. We installed 73-87 ralleys on my old buddies 91 for this reason. We did 6.5" vans up front & 8" trucks on the rear. Slight clean-up of the lower a-arm & we were good to go.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-10-2011, 04:55 PM   #32
muthstryker
I will tear into is this weekend and figure something out. Might just end up getting the truck ralleys.
Old 02-10-2011, 07:10 PM   #33
mooseknuckles
mooseknuckles's Avatar
not quite sure what the b.s. is on mine but they did not rub on my lca's after I switched wheels.
mooseknuckles is offline   Reply With Quote
Old 02-11-2011, 01:35 AM   #34
SCOTI
SCOTI's Avatar
Those are the 'styled' wheels & do not share the same back-spacing as the steelies from what I remember (it's been a few years since I played w/late model 88-98 stuff).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-11-2011, 08:39 AM   #35
73gmc454
73gmc454's Avatar
this wheel here has the least back spacing of the 7's I have ,its 3 1/2" ,they look like the yours and came from a 92 chevy ,they had the most clearence on my truck ,
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
