Re: my 6.0L showed up
wait its under here.... lol
its an 05 drive by wire, with 4l80e, It has a little over 100K, but I'm planning a cam change and if I need to I will throw in a set of rings, bearings and get the heads done. I noticed the tail shaft has a park brake on it, so not to sure how thats gonna work, hopefully I can pull it off and not have to buy a new out put shaft and housing, and the oil pan is different then a truck one, which might be good, cause it doesn't hang very low, as long as I have cross member clearance... Also it has the old style 88-94 column in it, so whats the chances of it not having VATS????? |
| Bookmarks |
