Old 01-31-2011, 02:32 AM   #1
rhdowns
Instrument light level improvement - my story
So I found this nifty article:
http://www.73-87.com/7387garage/interior/dashlights.htm
Decided to give it a try since I needed to lube my speedometer cable to stop it from making an annoying noise when it was cold.
The dashpad in my truck had been redone so I ended up having a few issues with it and found that one of my screw in spots on my instrument clusters was missing.
Anyway got the front plastic panel off, then the clear plastic part then couldn't figure out how to get the dash out. Finally figured out it was the speedo cable holding it in so removed the left vent and the duck so I could reach up in there and push the tab and unhook it. Then the entire cluster came right out.
I removed the bulbs all of which were original and some of which were burned out. I had issue at Wal-mart trying to figure out which bulbs I needed. The computer called for 161, 168 and 194. The only difference in the 3 are the watts rating. Autozone had no better answer so I just bought all 168's because they were the highest watts. I later looked close at the bulbs I pulled out and most of them were labeled 168 no matter if they came from the turn signal or just the regular back lighting area.
Next issue was I could not find chrome paint - the krylon and rustolem metallic is not shiny like the lid as he says in his article and do not produce the affect you are going for. Autozone didn't have any and two Walmarts had none in Hardware or Automotive. I ended up buying Scotch tape that was metal reflective. That ended up being a huge pain and took a couple hours to cut and paste in all the pieces of tape to cover all the areas needing covered but I needed to get my dash back together so I went with it.
Couple tips - when taking the bulbs out I was like how am I going to get these ones down in the holes out - I have skinny fingers but come on....then I had my ah-hah duh moment and figured out the thing that holds them in unscrews from the back of the cluster. Second tip bend the dumb metal frame to make it easier to get the cluster in and out - I broke one of the clips trying to get it in because it was caught just below the water temp gauge on the metal frame of the truck. It is alluded to in one of the articles I found on the web about replacing your gauges and just bending it a tad made a world of difference for me.
When I got everything back together I have noticed it is brighter - not like super awesome brighter but better.
One issue I found that may be related to the bulbs I got - when my head lamps are on and I turn on my turn signal they blink kind of slow. If I turn the lights off the turn signal speeds up. I'm guessing it is drawing too much power when all the lights are on?
I'll post some pics tomorrow. I'm a tired puppy.
86 K10 Shortbed
Skip White 383 \ 700R4 3.73 rear
rhdowns is offline   Reply With Quote
Old 01-31-2011, 02:21 PM   #2
rhdowns
Re: Instrument light level improvement - my story
It is not quite as bright as this picture lets on - this is in the garage with only headlights and these interior lights on and a 1 sec exposure.
Full album with large size photos can be found here:
http://picasaweb.google.com/rhdowns/...eat=directlink
86 K10 Shortbed
Old 01-31-2011, 02:24 PM   #3
Rons86
Rons86's Avatar
I did the same thing to mine and it improved vastly. I have since read that if you paint the cluster white it actually works better than chrome paint (reflects more light than chrome). Have not tried this, but would like to hear from some that have.
Rons86 is offline   Reply With Quote
Old 01-31-2011, 03:58 PM   #4
monte0185
monte0185's Avatar
I haven't done one of these but I have done one in a 67-72 and it made a huge difference. Need to tear mine apart to change the temp gauge so i planned on doing the same thing to this style to see how it works.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 01-31-2011, 05:29 PM   #5
Jonboy
Slots go on anything!
I used white and 168 bulbs, and it is noticably better than stock.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 01-31-2011, 05:51 PM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
I left the body alone and painted the backside of the reflector that goes around the gauges white...freshened it up nice.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 01-31-2011, 06:32 PM   #7
SCOTI
SCOTI's Avatar
White paint works as good or better than the 'chrome' paints & is easier to find.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-08-2011, 02:13 PM   #8
4pilgrim4
What an improvement!
I've gotta' do something about my dim and burned out dash lights.
Wonder if anyone has used LEDs as replacements for the existing lights or installed 1, 2 or 3 LEDs through small holes drilled in the bezels, for example?
4pilgrim4 is offline   Reply With Quote
Old 02-08-2011, 04:20 PM   #9
79bonanza
are you guys painting the black retaining piece also, like the back side where its a blue color
79bonanza is offline   Reply With Quote
Old 02-08-2011, 04:28 PM   #10
379redneck
379redneck's Avatar
I have red LEDs in mine and they look awsome, when they are all lit at the same time. Dont use the ones with the flat top on them, they dont shine the light straight out so it doesnt light up the guages well. They have a problem with staying on but I think its the sockets, not the bulbs that are causing it. I will check at work tomarow to see what brand the good ones are that I have in it. They are just 194 LEDs.
Im going to do this next time my dash is appart.
87 GMC Sierra 2500 4x4 350/TH350/NP203 Flow Tech long tube headers, throttle body spacer, Edelbrock Performer cam, true dual Flowmaster 40s, 6 inch Superlift suspension lift
2000 silverado extended cab stepside 5.3l. Stock for now
379redneck is offline   Reply With Quote
Old 02-08-2011, 06:17 PM   #11
JuicyJ
JuicyJ's Avatar
I just did my cluster 2 weeks ago and I just completly disasembled the cluster. It made the painting alot easier. I painted it white in the front and black in the back. This is due to black blocking the light and keeping it from passing thru the housing. I read another members thread and he did this and it improved his alot. Mine came out good. No complaints.
America is all about speed, hot nasty bad ass speed
JuicyJ is offline   Reply With Quote
Old 02-09-2011, 01:41 AM   #12
Blake_H
Blake_H's Avatar
I did mine in December with LED's and white paint. It worked great and I can actually see at night on my way home from work.
It was really easy and I am currently waiting for another order of LED's to do my crew cab with.
Blake_H is offline   Reply With Quote
Old 02-09-2011, 02:15 AM   #13
bigwheel15
bigwheel15's Avatar
So what leds are everybody using? Ive been thinking of ordering some from superbrightleds.com but figured id see what everyones using first.
bigwheel15 is offline   Reply With Quote
Old 02-09-2011, 02:21 AM   #14
Blake_H
Blake_H's Avatar
That's where I got mine from. I used the WLED-x5 on the cluster and on the light for the AC/Heater controls. It looks great.
Old 02-09-2011, 05:06 PM   #15
4pilgrim4
Decided to tackle this one today on my 83 Jimmy.
I ended up not removing the entire cluster. I removed the outer trim bezel, the clear plastic lens panel and the inner shield. Then I unscrewed and removed the gauges (they just pull out). The speedo can be pulled out enough to unclip the speedo cable.
Once the gauges were removed I was able to clean the plastic with mineral spirits and paint white.
For me this was easier than working under the dash to unhook everything. YMMV.
I called two of my favorite local auto parts to see if they carried LED peanut bulbs -- but -- no one there was interested enough to go look, so rather than drive 10 miles (plus) so I could go look on their shelves, I ordered on-line.
Last edited by 4pilgrim4; 02-09-2011 at 05:11 PM. Reason: add last paragraph & clean up some bad English
Old 02-09-2011, 09:44 PM   #16
kelsfine69
18 Till I Die
kelsfine69's Avatar
Thats all I did on mine and it woked nice. I didnt have to pull the whole cluster either and I changed all the bulbs too
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 02-10-2011, 12:44 AM   #17
rhdowns
Do the LED's just plug right in where the old bulbs go?
I really appreciate everyone adding their ideas and tricks. I wish I had thought of the white gloss paint before doing this it would have been so much easier than the tape.
I noticed one person say they could pull their unit out a little to unclip the speedo cable. I was unable to do that with mine it was very rigid and no play room so I had to disconnect the plastic heater channel and lay on the floor mat and reach in with my left hand and disconnect it. Akward but not difficult - I'm a kind of thin guy with thin arms and hands which definitely helped in this situation.
86 K10 Shortbed
Old 02-10-2011, 01:10 PM   #18
Telecasterjoey
I just did this yesterday after reading this post, Whoa what a difference!!
Telecasterjoey is offline   Reply With Quote
Old 02-10-2011, 10:39 PM   #19
4pilgrim4
You leave the back shell of the unit installed and pull the gauges out one at a time. The speedo is the most difficult as you have to unclip the cable. If there isn't enough slack you can get under the hood, locate where the speedo cable goes through the firewall and feed a few inches more in. That should be enough to allow you to unclip the cable from the speedo head.
You are fortunate to have thin arms and hands. I'm just the opposite, so working under dash boards is not something I do well at.
Old 02-12-2011, 02:28 AM   #20
kevinr1970
Me too!
But, and it has been a while since I did this, I was able to reach up from under the dash and release the clip for the speedo.
It was a beotch to either get it disconnected or clipped back on, I don't remember which right now.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-12-2011, 09:31 AM   #21
moneyeater
moneyeater's Avatar
Great improvement!
And sir i have to say that you have a real nice truck and that motor looks very powerfull!
Volker
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
´81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 04-06-2011, 04:34 PM   #22
75ChevyGuy
GM Parts Guy
75ChevyGuy's Avatar
In this picture the green plastic pieces that go over the turn signal bulbs. Does anyone know where to get them? My truck was missing them when I got it, and the yellow lights are driving me crazy!
1975 Chevrolet C-10 Custom Deluxe (DD/WIP)
1989 Chevrolet C1500 reg cab stepside (Winter Truck)
1977 Harley Davidson XLH 1000 (Summer Cruiser)
75ChevyGuy is offline   Reply With Quote
Old 04-06-2011, 05:34 PM   #23
HTX86chevy
HTX86chevy's Avatar
75CHEVYGUY - if you go to a hobby/craft store, im sure you could find some Transparent paper in different colors and make your own. I'm thinking of doing this and going with blue.
HTX86chevy is offline   Reply With Quote
Old 04-06-2011, 08:27 PM   #24
DetroitDan
DetroitDan's Avatar
this is interesting. I've got some packages of amber, red and clear leds left over, but they are all the type with the single bulb and the flat end. A member named 502ss has a build thread here on a crewcab and just changed his dashlights to superbright leds, looks wicked bright. I'd like to make mine look nicer, but in reality I always dim them way down so I dont lose my night vision (I do a lot of night driving), so I probably needn't bother brightening them up. The white paint things pretty interesting, I'll probably give it a try next time I'm in the dash for anything.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 04-13-2011, 10:09 AM   #25
HTX86chevy
HTX86chevy's Avatar
This is a setup i did on mine awhile back. I got some super LED's and white sticker type overlays from Whitefacegauges.net
I don't really like the way they came out, but its better than the dim yellow lights that I had....
