Old 02-11-2011, 01:39 AM   #1
o0oabizaio0o
o0oabizaio0o's Avatar
Smile c10 & c20 front/rear suspension pics?
hi guys! some pics of c10 and c20 suspension? to see the differences between the suspension, because i donīt know if my truck is a c10 or a c20 haha, to buy a 3" spindles,2" coil springs and 5" flip kit...
o0oabizaio0o is offline   Reply With Quote
Old 02-11-2011, 01:41 AM   #2
muthstryker
muthstryker's Avatar
Re: c10 & c20 front/rear suspension pics?
Do you have pictures of your truck?
muthstryker is offline   Reply With Quote
Old 02-11-2011, 01:47 AM   #3
78 Chevyrado
do you have rubber bushings where the control arms connect to the frame? If they are rubber, it's a C10, if they are steel with a grease fitting, they are C20 or C30.
Also, if its a stock C10, it will have five lug nuts per wheel, if its a stock C20 it will have 8 lugs per wheel.
78 Chevyrado is offline   Reply With Quote
Old 02-11-2011, 01:53 AM   #4
o0oabizaio0o
only this pic but tomorrow took some pics of the rear
Old 02-11-2011, 01:54 AM   #5
muthstryker
You have a c10 my friend.
Old 02-11-2011, 02:00 AM   #6
o0oabizaio0o
thanks for help me man now i can bought the correct parts! good luck!
Old 02-11-2011, 02:02 AM   #7
o0oabizaio0o
thanks man! good luck!
Old 02-11-2011, 09:56 AM   #8
Chlsnk
Chlsnk's Avatar
Clean frame !
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 02-11-2011, 10:51 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Not so fast there buddy. You now know that you have a C10 which is a 1500 or half ton depending on who is asking.
What you will need to know before you order spindles is what front brakes you have. There are two different sizes (1" and 1.25") and that has to be verified before you proceed.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-12-2011, 12:47 AM   #10
o0oabizaio0o
ok but i can use this flip kit in the rear?
http://www.summitracing.com/parts/BEL-6850/
Old 02-12-2011, 12:48 AM   #11
muthstryker
yes you can
Old 02-12-2011, 12:55 AM   #12
o0oabizaio0o
yes you can
thanks man!
