Old 02-11-2011, 09:16 AM   #1
zac
zac's Avatar
1970 350 Compression ratio
Does anybody know what the factory listed the compression ratio for on the 350/4bbl/4spd engine in '70? I think it's the original engine, it has 441 heads with June '70 date code, I can't see the block casting number, but I assume it's the usual 0010. The code stamped on the pad in front is VO622 TBB, which matches. I'm going to guess 9:1. Thanks in advance.
zac is offline   Reply With Quote
Old 02-11-2011, 09:47 AM   #2
cdowns
cdowns's Avatar
Re: 1970 350 Compression ratio
8.5 i think is closer
Old 02-11-2011, 10:07 AM   #3
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Our 69 3/4 ton GMC with the 300hp 350 was 10to1... that is/was stock. Gas was cheaper and better.
Tom Vogel is offline   Reply With Quote
Old 02-11-2011, 10:28 AM   #4
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
From the Specifications and Technical Data at the back of the 1970 10-30 series owner's manual:
Engine 350 V8
Color Code Red
Piston Displacement 350
Compression Ratio 9.0:1
Gross HP 255@4600
Net HP 200@4000
Gross Torque 355@3000
Net Torque 310@2400
Hope that helps!
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 02-11-2011, 10:48 AM   #5
10:1 350/300hp truck motor??? I don't think so. Never heard that before. If someone can prove me wrong I'd like to learn something.
Old 02-11-2011, 11:24 AM   #6
cdowns
cdowns's Avatar
that must b the elusive corvette optioned truck
Old 02-11-2011, 11:24 AM   #7
Dave
DND Trucks
Compression ratios vary a little from engine to engine, more or less. I'd perform a compression test just see where it's at now.
As far as a factory installed 300 hp and 10.0 compression 350 in '70 in a truck? Never seen one, nor does the GM basic engine data and power teams list any combo. Now a passenger car, that's a different story.
Dave is offline   Reply With Quote
Old 02-11-2011, 09:33 PM   #8
zac
zac's Avatar
Engine 350 V8
Color Code Red
Gross HP 255@4600
Net HP 200@4000
Net Torque 310@2400
Hope that helps!
This is what I was looking for, thanks! I think the 441 combustion chambers are a little tighter than the 487's that came later. My 350 spun a bearing last November, so I can't test it, or there's really no point. I slowly got that tired motor tuned last summer. I thought I had it about right, and it was a little pingy under load so I figured it was around 9. Of course it's in a K10 Burb with 31" tires and 3.08's so I'm sure that aggravates things. I wanted to use the 487 heads I had, but they were pretty bad, and the extra 441's I had looked good. The machine shop guy looked at the 487's and said "Well, I've seen worse, but you better leave those others ones." So my new motor will have thickish head gaskets and 89 octane, I guess. Thanks again.
Old 02-11-2011, 11:00 PM   #9
todd99
71 c20 longhorn custom camper. My motor was completely stock and had 11 to 1 compression, I had to check it twice just to believe it. My heads are stamped with 3978487 K250, not sure if that means anything.
todd99 is offline   Reply With Quote
Old 02-12-2011, 12:05 AM   #10
DT1
DT1's Avatar
That's nothing! My stock 350 in my 71 is 19:1. That's why I have always had to run premium.
DT1 is offline   Reply With Quote
Old 02-12-2011, 12:10 AM   #11
todd99
^^^ Are you mocking me?
Old 02-12-2011, 12:18 AM   #12
DT1
DT1's Avatar
Take it easy chief. I'm not mocking anyone. Just the numbers.
I have never heard of a stock 350 Gen 1 Chevy truck engine anywhere close to that. Maybe I could use a bit of education too.
Old 02-12-2011, 12:21 AM   #13
todd99
No worries, I'm not making it up. I am far from the original owner, it's possible someone tampered with it before I bought it. It looked stock.
