Old 02-11-2011, 11:05 AM   #1
West Texas Z
El Mero Mero Frijolero!!
West Texas Z's Avatar
Spindle and Shackled Truck Pics?
I'm looking at seeing what our trucks look lowered on 2.5 Spindles, and a shackled rear end...... 2x4 drop pretty much is what I'm refering to. I'd appreciate it. Post those pics men!! thanks.
West Texas Z is offline   Reply With Quote
Old 02-11-2011, 03:47 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Spindle and Shackled Truck Pics?
Mine is 2.5/4 with spindles/drop leaf springs in these pics:
http://slonaker.net/gallery/albums/u...al_c10_low.jpg
http://slonaker.net/gallery/albums/u...fore-after.jpg (bottom photo)
It is the drop amount you asked for but not the method.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 02-11-2011, 03:59 PM   #3
West Texas Z
Thanks, I'm wondering if I should 4.5x6 then? I would like to be a little lower than yours but not drag. Here is how my truck sits now.
http://i91.photobucket.com/albums/k3.../Photo0123.jpg
Old 02-11-2011, 04:11 PM   #4
Slonaker
Slonaker's Avatar
I like your truck. Nice!
Keep in mind that mine has new springs front and rear. If you use your old coils and leaves, it will likely sit a little lower than mine.
Most folks on here say a flip kit in the back with spindles and springs in the front makes for a good driving truck. I'm sure it would look good like that, plus flip kits are cheap and don't require you to cut your bed supports like the drop shackles do (unless you have the longer springs, which will clear the bed supports...).
Slonaker
Stock '01 Silverado
Old 02-11-2011, 04:55 PM   #5
87c10slammer
truck addict
im still trying to figure out how much drop is on mine.. every c10 i have had i always forget to measure it. any ideas?
trucks
87c10slammer is offline   Reply With Quote
Old 02-11-2011, 05:01 PM   #6
West Texas Z
Slonaker
Thank you. I think thats the route I'm going to go. Still debating and doing some research on the issue..... I want a level-low look with out air bags.
Old 02-11-2011, 05:42 PM   #7
Jonboy
Slots go on anything!
I would start with a 4/6 and go from there. Spindles, cut a coil from the front springs (or do drop springs), and a flip kit is a great start. If you want to go lower, cut more off of the springs and add shackles to the rear. My '79 was about 4.5/6, and I liked it. My '74 is closer to 6/8, and I like it even more. It takes a little getting used to, but I wouldn't change it a bit.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 02-11-2011, 06:55 PM   #8
West Texas Z
Yes!!! Like this.
Old 02-11-2011, 07:51 PM   #9
Jonboy
That's my '79. I bought the drop from CPP, and it was Western Chassis stuff. 2.5" spindles, 1 coil cut from the spring, rear flip kit. I used shock extenders in the rear so I could run the stock shocks. I also did the C-notch, but mostly because it came with the flip kit. I did the notch about a month after the drop. There wasn't much problem with clearance, but it also gave me a chance to clean up the bottom of the frame and bed. There are some pictures in my album of the truck next to my '74, when it was Scoti's. Scoti helped me with the drop, before we traded trucks. The '74 has shackles on the rear, and more spring cut. It's about 2" lower all around.
Old 02-12-2011, 09:55 AM   #10
bigd65
bigd65's Avatar
MAN West Texas,that truck looks good the way it is. I love that gray color. I wouldnt touch it
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
Old 02-12-2011, 11:53 AM   #11
TeXaS 86 C10
TeXaS 86 C10's Avatar
West Texas Z... i think you can solve your problem by just selling the truck to me ill come get it next weekend hahahaha
1986 LWB C-10 305/th400 Daily Driver and beer runner
TeXaS 86 C10 is offline   Reply With Quote
Old 02-12-2011, 12:49 PM   #12
mtchevytruck
mtchevytruck's Avatar
My truck has lowering springs in the front I believe due to all the spacers used to get into alignment. Dropping the rear but not sure how much. Want to get the front set before deciding on rear. Do you guys have problems with header to ground clearance? Mine look to be about 6" off the ground. And how badly is the ride effected? Lastly, I will be using this as a daily driver and probably be towing with this truck. Has anyone run into shorter air shocks to help out once lowered?
NW Montana
1977 C10 Bonanza short bed, 2wd
350/350, lowered 2", 10" Rally Wheels
Lots more needed.
1977 C10 Long bed, 2wd, less engine
Parst truck.
mtchevytruck is offline   Reply With Quote
Old 02-12-2011, 02:09 PM   #13
West Texas Z
lol thanks guys. I appreciate it.
Old 02-20-2011, 11:29 AM   #14
red02chevy
You should lower it 6/8.
red02chevy is offline   Reply With Quote
