Old 02-11-2011, 08:20 PM   #20
ray_mcavoy
Re: putting trim on and cargo light
Originally Posted by jojoman View Post
so if i get wider trim i got to get older rain gutters and vise versa also to polish your gutters what did you use what about taking them off you just use a small key wrench or what cuz them thing are pain in but
Yes, if you use the wider 73-80 cab trim you'll need to use the older (and slightly shorter) gutters. But the narrower 81-87 cab trim will fit with either style gutter.
I used some Mother's Mag & Aluminum polish. It works good on stainless steel too, and I think the gutter trim pieces are stainless.
I used a small 1/4" open-ended wrench to remove the gutter screws. I think some years use 7mm metric though. And if I remember correctly, you have to loosen all the screws and gently pull the gutter away from the cab a little before you'll have enough room to completely remove the screws.
An alternative removal method is to gently pry the stainless trim cap off the retainer rail. The retainer rail has notches to clear the screw heads so you have easy access with a small socket. However, this method carries an increased risk of bending the thin stainless trim when prying it off and/or snapping it back on.
ray_mcavoy is offline   Reply With Quote
