Old 02-07-2011, 01:20 AM   #76
laid_out_70
laid_out_70's Avatar
Re: building my first lowered truck
well here is this weeks update. didnt get alot done, helped a buddy of mine and went to a FFF meeting. im petitioning to join and so far so good i think.
well on friday afternoon i built a buddy a test pipe to replace his cat that he dragged a hole through. i cut off the cat's flanges and the rest is obvious.
then for the majority of the rest of the weekend i built myself a tranny crossmember. bolts to existing holes. nothing lined up and holes in the frame were different from one side to the other. its just temporary until i 'Z' the frame or buy a dropmember. i did go to town on it tho with my new flap disc. im really unsatisfied with the end product for the amount of time it took.
then i spent about 2 hours trying to figure out why i kept frying a compressor relay. after going over all of my wiring it ended up being the check valve in the leader hose. it was plugged and wasnt letting air go in either direction. im amazed that the compressor didnt blow up or anything horrific. so a new leader hose is on the To Buy List. good thing is that i was really unsatisfied with how slow the compressors were but now that i know it will be twice as fast im happy.
also talked to Nate from Porterbuilt this past week to see what headers he recommends so i would for sure have the correct fitting headers the first place. ordered those, two 45* bends, reducers and a 7.5' piece of exhaust tubing from summit. the headers and reducers showed up on friday.
wondering if this is the proper assemble for the reducers to the headers
also picked up 2 switches and another relay from autozone. 1 switch for compressors, 1 for my alternator since i need a diode but the closest radio shack isnt worth the drive.
still need to get a 'momentary on-off-momentary on' switch for the door poppers so i dont have to reach over to open the passenger door. also picked up 2 more lug nuts (all auto zone had) the last 11 i need are supposed to be there tomorrow and im still waiting on my tie rod ends to come in.
started brain storming ideas for upper shock mounts and came up with a great idea. it will complement the bridge design and be double sheared. idk what ill mess with next weekend, probably build the exhaust but who knows.
laid_out_70 is offline   Reply With Quote
Old 02-11-2011, 10:49 PM   #77
laid_out_70
well my last parts of the exhaust puzzle finished showing up today. 2 45* elbows and a 7.5' stick of 2.5" tube. hopefully everything i need to build the exhaust other then the hangers. i plan of doing that this weekend since im not going to the arizona show and shine.
Old 02-11-2011, 11:02 PM   #78
67chevy1series
67chevy1series's Avatar
nice parts!!!!
67chevy1series is offline   Reply With Quote
Old 02-11-2011, 11:16 PM   #79
laid_out_70
thanks. i got a bunch of nice parts, not many are on the truck tho :/
Old 02-12-2011, 09:58 PM   #80
laid_out_70
instead of working on my truck today i traded my ranger for this. 94 integra with a b20 and a gsr tranny.
Old 02-13-2011, 08:57 AM   #81
(joey)
(joey)'s Avatar
nice build.i like it
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline   Reply With Quote
Old 02-15-2011, 01:56 AM   #82
laid_out_70
thank you sir, check out yours, its intense
My Build Thread. 70 C-20, SFBD, angled Z, 3 linked. impressive for a noob?
http://67-72chevytrucks.com/vboard/s...d.php?t=438132
Old 02-17-2011, 02:04 AM   #83
laid_out_70
well i doubt ill get help here but doesnt hurt to try. im having a starting problem with my intergra. happened 3 times since ive got the car, once yesterday and twice today. i go to start it and i turn the key to start and the starter doesnt do anything. i can hear the relays click so i know the switch works i think. what should i check next?
also got the tie rod ends today.
Old 02-17-2011, 02:28 AM   #84
hotrodhomi
hotrodhomi's Avatar
test the power at the solenoid when someone turns the key. If you have power, replace the solenoid. In your honda case it would be easier, but not cheaper to replace the starter. it should come with a new solenoid.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 02-17-2011, 02:42 AM   #85
laid_out_70
thanks man, that was on my list to check. so if a solenoid is going out it will still work sometimes?
Old 02-17-2011, 12:04 PM   #86
hotrodhomi
hotrodhomi's Avatar
The solenoid can work intermittently, sometimes they will work when cold, but not hot. Also, try taping on your starter while someone holds the key over. If this makes the car start, replace the starter.
'66 impala ht
Old 02-17-2011, 09:05 PM   #87
laid_out_70
everything is pointing to the solenoid so i just went and ordered one this morning. i usually dont just throw money at my vehicles to solve a problem but ive been really busy lately.supposed to be in tonight and ill instal it tomorrow after work. thanks for the help
Old 02-21-2011, 12:01 AM   #88
laid_out_70
well i didnt really do much this weekend because it snowed. random weather. well i got a new leader hose thanks to ryan at viair, i just had to pay for shipping. put that in and a new relay. now the air system is good to go. really bummed out i have to build new motor mounts to clear the headers. :/
and this is what i came home to saturday night
ohh and for anyone following my starting problems with the acura i installed the new starter/solenoid and havent had a problem since
Old 02-27-2011, 04:34 AM   #89
laid_out_70
no progress this week. :/
Old 02-27-2011, 07:53 AM   #90
(joey)
(joey)'s Avatar
dont be scared of the white cold stuff.up here i had to dig my donor truck out of a drift to strip it down in -10 temps.but then again all of us Canadians live in an igloo so were use to it haha.trucks loookin good buddy
Old 02-27-2011, 09:47 AM   #91
coulter
coulter's Avatar
great build so far man!!! keep it up
coulter is offline   Reply With Quote
Old 02-27-2011, 05:11 PM   #92
laid_out_70
thanks guys. i just cant handle the cold what so ever. once its warmer im going to take a week of from work and try and finish the truck up for the most part. just want to drive it
Old 03-07-2011, 02:08 AM   #93
laid_out_70
well here is the update.
first i got the tie rods in
then the booster in
turns lock to lock laid out
here is the problem
well neither brake line attaches to the prop valve, both are too big. idk if its because c20 runs larger lines or because of it having drum brakes originally. basically where im at is if i have to redo ALL the brake lines i dont want to do them twice. which means that im going to tear down the truck and Z it and body drop it. and if im going to do all that im going to convert it too either 5 or 6 lug. id rather do it right the first time and not have to build brake lines and exhaust twice.
on to another situation. i might trade my Acura for this. its my buddies toyota. its body dropped on 19". problems with it include no interior and its a gross polluter. if we get the smog situation figured out ill probably end up trading him
Old 03-07-2011, 02:35 AM   #94
67chevy1series
well any painting going on with the frame?
Old 03-07-2011, 04:02 AM   #95
laid_out_70
yeh some day. lol
Old 03-16-2011, 12:51 AM   #96
laid_out_70
who want to not buy a truck?
Old 03-16-2011, 01:28 AM   #97
project 67 sub
project 67 sub's Avatar
might want to change that so you don't get yourself in trouble (don't ask me how i know) or get your thread locked or both, just an fyi but you have to be a paying/suppoting member to sell stuff on here, so you might want to just keep it posted on the other c10 forum.
project 67 sub is offline   Reply With Quote
Old 03-17-2011, 01:23 AM   #98
laid_out_70
yeh i know, lol
Old 03-19-2011, 09:12 PM   #99
big_b
cool build!
what size rims and tires are you running on your truck? i noticed they are 8 lug 3/4 ton? i wasnt aware you could buy lower profile tires for 16.5" rims but im new to this 8 lug game.
thanks
big_b is offline   Reply With Quote
Old 03-25-2011, 02:57 AM   #100
laid_out_70
update, im getting most of the stuff needed to convert the truck to a dually. it will sit for awhile but i dont plan on selling it unless i have to. and here are some pics of the new DD.
