Old 02-12-2011, 01:42 AM   #1
VA72C10
VA72C10
VA72C10's Avatar
Re: Project: Recycle
Progress? are we talking about progress?
Old 02-12-2011, 02:09 AM   #2
SCOTI
SCOTI's Avatar
I took multiple pics when documenting/adjusting all the angles. But the pics just don't show well. You can't read the DAF display because of the pic & I doubt you could tell a difference of the rear housing with & w/o shims.
It's been a tedious process to say the least....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-12-2011, 10:57 PM   #3
SCOTI
SCOTI's Avatar
Ok, pics & info for the hounds. I got the trans spacer finished today. Painted it & the shims I'm using to dial in the front working angle for the drive-line....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-12-2011, 10:59 PM   #4
SCOTI
SCOTI's Avatar
Here's an 'exploded view' of the shims, spacer, & poly trans mount w/hardware plus everything installed....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-12-2011, 11:04 PM   #5
SCOTI
SCOTI's Avatar
While in between coats & waiting for paint to dry, I prepped all the truck-arm x-member pieces (prep = stripped to bare metal). I had already cut & trial fit everything for raising the d.shaft hoop. I got everything welded up & then did post welding 'clean-up'....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-12-2011, 11:11 PM   #6
SCOTI
SCOTI's Avatar
Then I installed the trans mount/spacer assembly & d.shaft. I took a measurement @ ride height & had a little over .750" clearance. There's about .1875" clearance @ max drop/compression (air'd out)....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-12-2011, 11:22 PM   #7
SCOTI
SCOTI's Avatar
And the 'working angles': 2.4° @ the front (trans to d.shaft); 1.5° @ the rear (90°-88.5= 1.5°; pinion to d.shaft); & the descending d.shaft slope from the trans to the pinion....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
