Quick Brake Booster Question
I am putting a power brake booster on my truck. I read on a previous thread that tapping into the vacuum fitting on the intake runner can lead to burning a valve/piston if the booster has a leak, so you want to tap into vacuum at the carb base.
The only tap I have on the carb base has the PCV hose going to it. Would I be OK tapping between the PCV valve and the carb (T fitting), or could it cause problems with the booster? Thanks for the help.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
It'll Buff Out!
![]() Join Date: Apr 2007
Re: Quick Brake Booster Question
is there a port on the back of the carb that has a plug in it you can remove and use?
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
I don't see a port back there (should be large 3/8" or so I thought). Just the one on the front that the PCV goes into.
Q-jet carb. Thanks
It'll Buff Out!
this is what I have, only thing is maybe earlier q-jet didn't have it. this i'm not sure of.
I tapped it into the PCV for now and will leave it unless I get info that it is hazardous.
I will say, power brakes are a very nice option to have.
