Old 02-12-2011, 09:57 PM   #601
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
SO....Found out what was wrong. This is one of them times i should have listened to the wife. First time she road in it she said it sounds like it has a miss. Well she was sure right. Pulled cover and coils and found this. Not sure what happened but nothing is bent or broken. Push rod is not bent, valve moves free up and down and spins freely, spring is ok, retainer is ok. Only thing found is scratches on valve cover. This kind of luck will not happen again to me. The rocker was actually holding the push rod up out of way. Let me tell you i was VERY happy to see this. It meant i most likly will not have to pull heads. Went ahead changed #1 intake valve seal. An added benifit i the horible exhaust noise is gone. And has about 60 more hp. I mean that big burb will plant you in your seat. Gave my bro, his gf, my wife, kid ride to day and when i punched it everyone stoped talking and just smiled. Even my bro was impressed and he is VERY hard to impress. It is funny how smoth it ran on 7. I can also lock up my converter now. Befor when i locked it up the hole truck shaked bad. Now it is very smooth. I am so happy with engine now.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-12-2011, 10:12 PM   #602
joe231
joe231's Avatar
Wow!
Congrats on the easy repair!!
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-12-2011, 10:52 PM   #603
harnalien
TruckincrazY
harnalien's Avatar
Outstanding news buddy! Nothing like a free fix. You had me nervous and starting to doubt the indestructibility reputation of these motors. I'm gonna have a speed shop install my cam next week. I don't want to run the risk of messing something up and it costing me more than they would have charged in the first place. Sounds like you're really enjoying the power. That's what I'm forward to.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 02-12-2011, 10:59 PM   #604
85burb
85burb's Avatar
I worked at chevy for a while and i talked to a guy that has worked there the hole time these motors have ben out and the only 2 that he has ever seen mess up. One a cam went flat and one broke a valve spring and droped a valve. That is it. Everyone on here that has got used motors has not really had a problem with them. They are amazing. Most reliable engine i have ever seen. I have also worked at ford and they had major problems when i worked there in 07. That is why i got this motor i wanted to drive the wheels off and not really worrie.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-13-2011, 03:07 PM   #605
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
glad to hear it was something simple...but uh.....didn't you put in the p-rods and valve springs to go with the cam?
the LSx motors (early models, 6.0 included) have had one issue....CSK or cold start knock. The pistons rock in the bore as they cycle up and down until everything comes up to temp...giving almost a diesel like clatter.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-13-2011, 03:39 PM   #606
flamingbig10
6.0 powered square
flamingbig10's Avatar
good to hear it was a easy fix
Originally Posted by 85burb View Post
. I have also worked at ford and they had major problems when i worked there in 07. .
all the late model v8 ford engines are junk, at my work I see several 4.6 with blown at spark plugs and 5.4 when you pull them at they usually break off in the cylinder because the spark plugs have a sleeve that sticks about inch past the treads and get carbon build up , and any ford Diesel past the 7.3 is trash they have nothing but problems
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-13-2011, 08:05 PM   #607
85burb
85burb's Avatar
Very true. My bay at ford was right where the customers would drive up and i always knew what that noise was befor they even got out of there truck. Compleat junk if you ask me. They have inproved over the years but still had work to be done at that poing.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-13-2011, 08:07 PM   #608
85burb
85burb's Avatar
..............YES i put them in....What are ya getting at??? Just kidding the best i can tell is i did not get the push rod in the lifter right or that is the reason behind tightening them in fireing order...Cause the bolt was odviosly loose. Runs like a champ now....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-13-2011, 08:14 PM   #609
85burb
85burb's Avatar
Just figured I would post a pic of buddy after his bath. Looks great.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-13-2011, 08:29 PM   #610
85burb
85burb's Avatar
Got some more done today. Got my uego and tach installed. That wideband is very fast. It jumps around about as fast as conditions change. I figured it was going to be slow but it flys around so fast. If i am crusing and then punch it the needle folows my foot just about. It idles at 11.5-12 but if i punch it it dives to sometimes 18 to 1. But most of the time it is 13-15 to one. I will install my digger acceleator nozzel and maybe go up one or two jet sizes. And lean out idle a 1/4 turn i think.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-13-2011, 09:02 PM   #611
fencepost
fencepost's Avatar
Not really an issue I guess but it is for me, torn between 6.0 and 5.3, have you had a chance to check fuel mileage. I know the bigger cam will probably hurt it a little. I'm looking at going with a carbed LS set up on my 94Z71 when she gives out, will be a daily driver.
fencepost is offline   Reply With Quote
Old 02-13-2011, 09:12 PM   #612
85burb
85burb's Avatar
On the gas milage it is the same or better then my old 350 with same carb. The most recent milage i got out of my 350 is 8.5 mpg. But my speedo is way off. At 55 on my speedo i am doing 65...found that out hard way. I drove it hard from last tuesday on maybe a little more then 1/4 tank. Filled it tuesday and have little less then 3/4s left. I mean i have gave it hell. Prob punching it 3-4 times a day. Maybe burn out here and there sence i fixed rocker sat. I would deff do the 6.0 if you dont you will always regret not having the extra power. I dont even realy have to push on gas to keep up with traffic. I know if i did a 5.3 i would alway want more. I had thoughts of a 4.8 or 5.3 in my burb but i dont think i could have lived knowing for a few hundred more bucks i could have had a 6.0.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-13-2011, 09:20 PM   #613
harnalien
TruckincrazY
harnalien's Avatar
That's the exact dilemma I had for the longest. I wanted to get a 5.3 just to get it quicker than it would take me for the 6. I knew I would regret it, so I held out. Now I'm about 2 months from getting the 6 in and burning up the streets!
Old 02-14-2011, 04:26 AM   #614
MTCK
MTCK's Avatar
Awesome progress! Glad you got the tach and the O2 sensor in! One thing I learned with my O2 is that 14.7:1 is not necessarily where you want to be on the a/f ratio. My truck does not like to idle that lean. It is much happier at 13.5 - 14.0 :1, so why fight it. As for idle quality I still ended up going for max vacuum. Now we just need some videos!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 02-14-2011, 12:11 PM   #615
68GMCCustom
Looks good. IMHO you'll need to be seeing 12.4-13.2 or so when your on it (depending on how hard). For idle go for best vaccum reading. For cruise you can go to 14.2-14.7:1's (even 15.0's is possible at light cruise) or there abouts.
Instead of 14.7:1..... I'm guessing you'll be at 13.0 or so most of the time.
Kurt -
Old 02-14-2011, 09:41 PM   #616
y5mgisi
Second Chance Program
y5mgisi's Avatar
Is it still smoking?
y5mgisi is offline   Reply With Quote
Old 02-14-2011, 11:34 PM   #617
85burb
85burb's Avatar
Not at all!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-14-2011, 11:38 PM   #618
85burb
85burb's Avatar
I will hook vacuum gauge up to it this week end. The thing i dont get is lets say i am in 2nd at 13 or so then it shifts and i dont push on gas any more it goes leaner. Then it shifts to overdrive and it is in the 15 to 18 range. If i give it gas fast or slow it goes to maxed out 18. But if i put more throttle in it slowly comes up. I was going to try .35 nozzels for the pump. But i am not sure what to do about the lean at cruse. If i punch it its about 13-14. How do you faten up part throttle?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-14-2011, 11:39 PM   #619
85burb
85burb's Avatar
Mine idles at 11.5 to 12. Will put gauge on vacuum this week end and see what i get.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-15-2011, 10:13 AM   #620
68GMCCustom
smell fuel? that seems to be a bit....maybe a tad... rich.
Kurt -
Old 02-15-2011, 11:24 AM   #621
MTCK
MTCK's Avatar
http://www.chevyhiperformance.com/te...age/index.html
Good article here. It's a little over my head, that's why I went with EFI...
-Marcus
Project Plow Truck
Old 02-15-2011, 08:24 PM   #622
85burb
85burb's Avatar
Deff smell fuel. If i am cruzing and i let off then push everso lightly my af goes to 9.9-10.2 But if i push little harder it goes to normal or lean. Buy going down highway it i throttle in to it at all it pegs out at 18 then slowly goes to 15 or so.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-19-2011, 09:54 PM   #623
85burb
85burb's Avatar
Well got sometime to play today. Installed my #33 fuel nozzle or accelerator pump and checked the float level and set idle mix to max vaccum. As it turns out my float level was perfict, my idle mix that i turned in a 8th turn the other day was perfict and i also put the med spring in my quick change vac secondary pod. Wow what a differance. Absolutly no hesitation at all any more. When i punch it while driving the wideband takes slight dip to rich not way over to the lean side any more. Even in overdrive it does not hesitate when i throttle in to it. It is amazing. VERY HAPPY with set up other then still a little lean on highway. Other then that it is GREAT
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-19-2011, 10:07 PM   #624
MTCK
MTCK's Avatar
AWESOME! Can't wait to see some videos! A little lean is OK - that saves you $$$. A lot lean, not so much - that costs you $$$.
-Marcus
Project Plow Truck
Old 02-19-2011, 10:29 PM   #625
joe231
joe231's Avatar
Cool
Sorry if I missed it, but what kinda mileage are you getting?
CHEVY ONLY
