Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Electrical
Old 02-12-2011, 11:17 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Tach Dash Installation/Rebuild FAQ
After finally tracking down the correct mounting location for the tach wire to pass through (thanks VA72C10) on the firewall. According to his build thread (here) [with pics here], the correct location is between the wiring distribution block and e-brake holes.
A quick call to lolife99 and a few weeks later, I was free and he came down with a uni-bit. If you've never used one of these and need to drill a large hole fast, this is the bit for you. It's actually a "step bit" containing several different diameters within the bit, which "step" up while continue drilling. The tach wire needed to be drilled to just at .75" or 3/4" diameter to accomodate for the rubber snubber on the wire. Here's a shot of the uni-bit with an extension and of the gradual drilling process.
The end result will look like this, although it is roughed in at the moment. A little clean up under the hood and we'll be good.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline
