Re: 86 1/2 ton lwb to 1 ton dually
Yes, you can use your springs. all you need are the hangers from a 1ton and the dana70hd rear axle. As stated the rivits will need to be removed to get the hangers off of the frame. I use my grinder and put an x in the head then take a cold chisle and brake the rest of the head off. The rivit can be punched through the frame or you can beat a pry bar between the hanger and frame for removal. Your handers can then be bolted back on through the holes that the rivits were in.
1949 Five Window, 1973 Step Side, 2000 Z71
