Closed Thread
Old 02-13-2011, 11:33 PM   #1651
ItsRandy
ItsRandy's Avatar
Re: What did you do to your truck today!
Painted 1/2 of my frame today.
ItsRandy is offline
Old 02-14-2011, 12:35 AM   #1652
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Originally Posted by cokeb View Post
Magwakeenercre2jh, what did you use to remove the markings off the original plastic lens prior to installing your tach?
Craig
A jigsaw. I cut the original lens out and used the one that came with the tach. The white around the edge is some 12 or 14 gauge
wire with the ends cut on the bias and pressed in with a touch of glue.
The logo is my motorcycle "club"...a sticker reduced on th e printer, cut out and glued to the black face of the aftermarket tach.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 02-14-2011, 12:42 AM   #1653
magwakeenercew2jh
Sweet!
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 02-14-2011, 12:59 AM   #1654
dan42
dan42's Avatar
I fixed my squeaky clutch pedal - I ended up having to pull the dash to get at the top hinge, but it doesn't squeak now - very nice.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline
Old 02-14-2011, 01:10 AM   #1655
cokeb
thanks, when my son and I did his we left the original lens untouched and at times it seems distracting.
Craig
cokeb is offline
Old 02-14-2011, 02:11 AM   #1656
blazerboy_4life
70Custom10
I ordered Aluminum valve covers for my new motor that should be done next week!
blazerboy_4life is offline
Old 02-14-2011, 04:25 AM   #1657
project 67 sub
project 67 sub's Avatar
installed the rear bags and lines, aired it up and set it on the ground. then i moved the jack stands to the front, so i can tear it apart in the next couple of days or so to do the front bag and drop spindle install. also installed the chrome exhaust tips.
project 67 sub is offline
Old 02-14-2011, 05:56 AM   #1658
steelscout
Words under my name
steelscout's Avatar
Changed out water pump due to bad bearing, and turns out the water pump was for a 69 corvette??? brought old one with me and matched up. Replaced while it hailed on me on Saturday night...and replaced both belts. Need to replace pump pulley since that happens to be the cause of my screech when I rev it. After work it will be replaced. And then put it all back together. oh yeah...got the driver door to lock now.
69 Chevy CST/10 "Project: Bloody Knuckles" my slow going project.
2010 VW Golf, daily driver
Wrench Rookie
steelscout is offline
Old 02-14-2011, 01:28 PM   #1659
eagleuh1
eagleuh1's Avatar
Replaced my heater blower, since it wouldn't work while working in Louisianna for a month, while they had the rainiest/coldest Jan on record. Fogged up windows the whole time. Checked fuses,switch, voltage at blower connector, all good. Replaced motor, No work. Tapped the ground wire above motor with screw driver, works great. Anyone need a 40 yr old working blower motor. Also installed my licence plate frame to rear sport bumper. Still need to buy light for it. CHeck your grounds. Jim.
eagleuh1 is offline
Old 02-14-2011, 08:55 PM   #1660
project 67 sub
wire wheeled and grinded down the a arms, want to get them sand blasted before paint and reassembly. gonna go back out and start tearing apart the front end in a few minutes
Old 02-15-2011, 12:47 AM   #1661
ItsRandy
ItsRandy's Avatar
Rebuilt the upper and lower control arms today, became a man in the process.
ItsRandy is offline
Old 02-15-2011, 03:15 AM   #1662
project 67 sub
got one side of the front end all torn apart, need to do some cutting on the spring pocket tomorrow, gonna be cutting out the top for air line, valve, and bag bolt access
Old 02-15-2011, 03:52 AM   #1663
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Attachment 699634
Attachment 699635
Don't forget to post pics of your cut out. I'll be doing the same on mine and want to see what'll work. I've seen folks cut out a hole in the outside edge too.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline
Old 02-15-2011, 04:56 AM   #1664
mmmBoost
yesterday
tonight
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline
Old 02-15-2011, 05:01 AM   #1665
project 67 sub
oh for sure i will be posting pics, will most likely, (later), run the valves right directly at the bag port, and the line straight into that with no elbows lol. can you say fast haha.
edit: ah i have seen that too, but it wont work for me lol. that and i am trying to be a little different
Old 02-15-2011, 03:24 PM   #1666
cooter472
cooter472's Avatar
Installed new Eaton posi unit with new bearings.
71 C10 2WD,472 Big Block Buick
B4B Intake,800 cfm Q-Jet built by(Fred Catlin)
Comp Cam 254/268@ .050 .530/542 lift
1 7/8 supercomp headers, 2 1/2 X-Pipe/ Magnaflow's
Mallory fuel system
Igniter Flame thrower Ignition system
TH350,Hughes 3500 Converter ,3.73's
Its just an old heap, but its my hot rod!
cooter472 is offline
Old 02-15-2011, 06:28 PM   #1667
wannabelow68
New oil pan gasket, and bolts a 700r4 up to my 250. All it took was some blood,sweat, lack of sleep and help from zip ties and all thread!
1968 Chevy c10. CPP drop and disc brake conversion. straight six 250/powerglide. YUP!!! truck club
wannabelow68 is offline
Old 02-15-2011, 07:44 PM   #1668
mcmlxix
Collector of Projects
mcmlxix's Avatar
Ordered my Art Carr shifter....
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Old 02-15-2011, 08:48 PM   #1669
trkfrk
trkfrk's Avatar
[QUOTE=mcmlxix;4488882]Ordered my Art Carr shifter....
I like it..
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline
Old 02-15-2011, 08:58 PM   #1670
unreconstructed1
nec absolutum
unreconstructed1's Avatar
sent my 96 to the transmission shop and ordered the new filler neck grommet for the new gas tank on the 69...
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants."~ Thomas Jefferson
1967 GMC C1500 LWB 250/3 on the tree-
1969 Chevy C/10 SWB 350/TH350
1996 Chevy Silverado LWB 350/4L60E
1997 Chevy K2500 350/4L80E
unreconstructed1 is offline
Old 02-15-2011, 08:58 PM   #1671
mcmlxix
mcmlxix's Avatar
[quote=trkfrk;4489107]
I like it..
Thanks.. they joke it looks like an old arcade game joystick.. but I plan making this work anyway....
Rich
mcmlxix is offline
Old 02-15-2011, 09:01 PM   #1672
67swb72klb
67swb72klb's Avatar
looked for a lt1 for the 67 swb then blocked out the tailgate for 72k10 cause this guy keeps telln me my bed sides are gona start slaping around if i dont get one on soon
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline
Old 02-15-2011, 09:47 PM   #1673
Sicklajoie
The Niner
Sicklajoie's Avatar
Got my steelies back from the painter (nice and white) and ordered my tires (Michelin LTX M/S2 265/75/16) today.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline
Old 02-15-2011, 09:52 PM   #1674
60ratrod
yes, i do
60ratrod's Avatar
looked at a 67 chevy parts truck that a guy is parting out and is going to let me have the front end sheet metal for only $50! so my 72 gmc will get the nice sleek look of a 67.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline
Old 02-15-2011, 10:36 PM   #1675
Mike J
vw guy & now c-10 guy
Mike J's Avatar
finally removed my old cracked windshield!
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline
Closed Thread
