Old 02-14-2011, 02:06 AM   #101
Bugeyev8
Bugeyev8's Avatar
Re: My 1962 C10 Build Thread "Grandpa's Truck "
Thanks Captainfab !!
I used saran wrap plastic wrap tacked to the wood with staples first, the glass will not stick to the plastic wrap, then the cotton material and then the resin and fiberglass mat, three layers of mat, I did two layers and then knocked it to shape woth 36 grit om my DA, then the last layer laid out smooth, I used blocks between the two plywood pieces.. loose not screwed down, I screwed 4 screws into just the two pieces of plywood so the parts would seperate after everything was dried and so I could get to the screws and not hit them with the jig saw, then used a template I made to cut the hole for the fan from the top side, I trimmed it while in the form and it popped right out, If I had it to do again..I would leave it on the form a little longer because it pulled in , along the middle of the wide edges, but I am not going to make another one, I used those threaded inserts 10/32 used for furnitiure to mount the fan to the ring of plywood, I guess I could have used aluminum and glassed it into the part but..I think the wood will be ok
Bugeyev8 is offline   Reply With Quote
Old 02-14-2011, 02:15 AM   #102
Captainfab
60-66 Nut
Thanks for the rundown. I was thinking of something like saran wrap. So did you use something like an old t-shirt to get the basic shape?
Old 02-14-2011, 03:30 AM   #103
Rannos
Rannos's Avatar
That is some impressive work on the rust repairs man. Good job!
Rannos is offline   Reply With Quote
Old 02-14-2011, 12:08 PM   #104
Bugeyev8
Bugeyev8's Avatar
I used a cotton bed sheet the t shirts had seams and were not large enough between the seams
Old 02-14-2011, 12:10 PM   #105
Bugeyev8
Bugeyev8's Avatar
Thanks allot, It was a long process with the rust repairs...I try not to remember, I did all the metal work in a 2 week period 8rs per day, I burned myself out on the truck, just getting back into it again
Old 02-14-2011, 01:55 PM   #106
smilts60
You have came a long way on it and its looking good.
smilts60 is offline   Reply With Quote
Old 02-14-2011, 02:07 PM   #107
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
The shroud came out great. What CFM is the fan rated?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-14-2011, 02:23 PM   #108
Bugeyev8
Bugeyev8's Avatar
I don't know off hand but its a big Hayden...paid allot for it about 12 years ago and it cooled the TPI with the stock radiator without a shroud for all these years, I will check the CFM its on the side of the fan...I was just looking at it the other day
Old 02-14-2011, 07:11 PM   #109
Bugeyev8
Bugeyev8's Avatar
Took a few hours of work but...I figured out a good way to mount the new radiator to the 62, the 62 does not have a radiator mounting x member like the 63-66 have so I got a bit creative, made some brackets and used some rubber isolators from a jap car in the junk yard, I am pretty sure it was a 90s Nissan Maxima, then made some plates and riveted them to the radiator, still need to mount the top but I think I will use one center mount to teh hood latch striker plate bolts, top hose is going to work which was a 1992 GTA trans am...lower is stock 62 but will not work...off to the parts house with my exhaust preheater hose bent to fit and see if I can find anything that will work, if not I will get some stainless mandrel bent tubing and tig them together to form the bends and use two short hoses on each end
Old 02-15-2011, 02:03 AM   #110
Captainfab
60-66 Nut
Ahhh that makes sense.
Old 02-15-2011, 11:11 PM   #111
1adam12
1adam12's Avatar
Glad your keeping it doing good job so far..By the way thanks for hooking me up on the tailgate and fender thay really helped a lot..been driving mine a bit but the ratio for the rear end and that granny low 4 speed sucks driving it to work..Keep it up I will see ya at Ellios soon.............
1adam12 is offline   Reply With Quote
Old 02-15-2011, 11:51 PM   #112
Bugeyev8
Bugeyev8's Avatar
Swap that rear end out man !! I have a 3.08 in mine, I got a 12 bolt from a 79, I had to make a choice...Posi or going fast on the freeway, the posi went to the dumps, someday I will throw one in there again
when does the Elios show start again ?
Old 02-16-2011, 12:20 AM   #113
faribran
i am curious about how you shaped the patch for the top corner of the cab..... can you share some tips about this? thanks
i like what you have done for far..
faribran is offline   Reply With Quote
Old 02-16-2011, 01:21 AM   #114
Bugeyev8
Bugeyev8's Avatar
The cab corners came from another truck, I just cut my roof till I hit good metal and cut the patches to fit, If there is anything else I can help you with let me know
Old 02-16-2011, 09:31 AM   #115
1adam12
1adam12's Avatar
I think it starts again in april or may when i find out I will let you know...
Old 02-20-2011, 02:04 AM   #116
Bugeyev8
Bugeyev8's Avatar
I waited the whole day for the rain to stop...at 4 pm it stopped and I was able to jack up the 62 and remove the RH wheel and all the brakes, I cleaned up all the parts and got it ready to go back together with new slave and shoes....and the rain started again...better luck tomorrow
Old 03-07-2011, 04:07 PM   #117
Bugeyev8
Bugeyev8's Avatar
Got allot done the last few days, its fired up again after relocating the EFI pump under the cab from under the hood, re did allot of the engine wiring and got the dash and gauges back in and working, radiator is in for good and all hoses are installed and full of water/coolant, steering column is in for now...getting a different one soon ...so this one will get trashed...its worn out
Got the last parts of the dash painted today and its back together
I decided to go with Hot Rod Flatz paint so the 800$ of the factory green is just going to sit here...I should have thought that one out a bit before dropping the $$...oh well
Old 03-07-2011, 04:10 PM   #118
Bugeyev8
Bugeyev8's Avatar
also knocked the dents from the sail panels and polished them up a bit, its hard to show in detail with pics, they look allot better...its very hard to polish in the grooves, I am going to get to the polishing store this week and will see what they suggest
Old 03-08-2011, 04:30 AM   #119
burbluv
burbluv's Avatar
Looking great!
Thanks again for the heater lead.
Talk to you soon.
burbluv is offline   Reply With Quote
Old 03-31-2011, 09:21 AM   #120
1adam12
1adam12's Avatar
Finally got the roof done here is a pic..........
Also heres a pic of my co driver
Old 03-31-2011, 10:46 AM   #121
Bugeyev8
Bugeyev8's Avatar
thats great, how did you end up fixing it ?
Old 06-16-2011, 08:35 PM   #122
Bugeyev8
Bugeyev8's Avatar
Got a little paint sprayed today..working in a small garage sucks...and what sucks even more is dust and dirt falling in fresh paint..oh well
oh also ordered the division bar inserts...guess when I got the kit from Chevy Duty 12 years ago...they shorted me the linings
Old 06-17-2011, 12:52 AM   #123
Captainfab
60-66 Nut
Looks good
Old 06-17-2011, 09:03 AM   #124
dean jendro
Old and crusty
dean jendro's Avatar
Nice build and a great story!! Keep up the good work.
dean jendro is offline   Reply With Quote
Old 06-20-2011, 01:17 PM   #125
Bugeyev8
Bugeyev8's Avatar
Thanks for the kind words !!
1962, lsa supercharger, rust repair, tuned port
