Old 06-23-2003, 02:43 AM   #1
SEVEND2
SEVEND2's Avatar
need help with my 72
Ok, just been driving it past couple of days, replaced front calipers and brakes becuase front clipers locked up. any how
say i am getting off the freeway/highway when i drive for a little while the front starts to shake bounce around and i exit the ramp and it bounces more when i aply the brakes, it bounces a little when i take off, and then smoothes out. when i come up to the next light i let off the gas and slow (with out hitting brakes) and the front bounces alot. and it that way till like it sits for a while a few hous and then its fine again till i drive it for a while again.
ANY IDEAS WHY OR WHAT COULD BE THE PROBLEM? SHOCKS, BRAKES??
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 07-05-2003, 07:00 PM   #2
rhett
tire wobbel
i am not sure but it my be that you have warped rotors,or drums. i have had this happen to a coupel of people i know. they replaced the rotors and that stopped the problem. like i said just an idea. have a good one.
rhett is offline   Reply With Quote
Old 07-06-2003, 01:40 PM   #3
SEVEND2
SEVEND2's Avatar
thanks for the post got it figured out, It was the distance between the master Cylinder and the booster, the shaft inside wsa to long, and would not let the shaft go back far enough to open the relief valve part to let the brakes release
and stage 2
Old 07-06-2003, 01:59 PM   #4
rhett
Cool
gald you found the problem. i wouldnt have guessed it was the brake push rod. have a good day, later.
