Old 02-13-2011, 08:12 AM   #1
roofingbloke
C notch or Step notch
I have a 63 long fleet,
I will be using air bags between the chassis and controll arms & 2" lowering blocks, also running 20" x 10" with 40 profile tyres,
So i am not sure if to go with a c notch and a step notch,
Any ideas guys,
roofingbloke is offline   Reply With Quote
Old 02-13-2011, 11:23 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: C notch or Step notch
All you need is a C notch. You stock arms will limit how low you can go.
Old 02-13-2011, 11:25 AM   #3
roofingbloke
? what if the air bags were in a different place,
Old 02-13-2011, 12:43 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Unless you change/modify your rear suspension system, your stock arms are still the limiting factor regardless of where your bags are mounted.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-13-2011, 12:44 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
In theory,... you could go 3" lower.
(the compressed height of most 2600 convoluted air bags is 3")
This would require you to use a smaller step notch.
Keith
Convert to disc brakes.
Old 02-13-2011, 01:31 PM   #6
roofingbloke
Thanks lolife99, I think thats the other option i was thinking about,
I dont want to do a c notch and then rip it out for a step notch, Better get under the truck with my tape measure,
Thanks guys for your help. any pics of alternative bag positions ?
Old 02-13-2011, 01:59 PM   #7
nastyc10
nastyc10's Avatar
Go with a small step notch. You will probably want to go lower than what a c-notch will get you. No use in doing it all over when your not happy with it. I've been there. You may have to trim the inside bottom of the frame because the trailing arm may hit it when you air down.
I would also make sure this is all you really want. It sucks to do it all and then wish you would have put in a bigger notch so you could go lower.
nastyc10 is offline   Reply With Quote
Old 02-13-2011, 02:10 PM   #8
SCOTI
SCOTI's Avatar
A smaller step notch will likely be stronger vs. a c-notch that removes 60% of the frame material directly above the notch area. That frame height is where the strength (or weakness) is.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-13-2011, 06:07 PM   #9
kev2809
low n' slo
kev2809's Avatar
well, i have 2" blocks with bags in place in of coil and the axle goes all the way up through the frame, so a small c notch but would be holding me up a few inches at least. i went with a huge step notch lol...but better safe than sorry. i hate redoing things. i do want to add though that the bags are hammered flat when its aired out. im not sure if they are designed to be that smashed flat...maybe someone will chime in.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-13-2011, 06:58 PM   #10
SCOTI
SCOTI's Avatar
Depends on the bag. Some have internal bump-stops, some dont.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-14-2011, 04:55 PM   #11
kev2809
low n' slo
kev2809's Avatar
dominators...im not sure if they do..
i know the slams do though
-_--_--_ _________
Old 02-15-2011, 05:02 PM   #12
roofingbloke
I am know looking at different air bag locations, looks like i will be going for a Porterbuilt step notch,
Any pics anyone,
I have just been looking at the porterbuilt web sit and i am not sure of the difference between the tubular/adjustable trailing arm x member and the carrier bearing x member,
Old 02-15-2011, 06:03 PM   #13
PBFAB.COM
PBFAB.COM's Avatar
Any pics anyone,
We have a couple different variations of the Adjustable Trailing Arm X-member:
One to be used with a one-piece drive-shaft; and another for a two-piece drive-shaft. The version specific to the two-piece driveshaft has a mounting pad for the carrier bearing.
The carrier bearing crossmember does not have mounting pads for the trailing arms.
One Piece Version:
Two-piece Version:
Carrier Bearing X-member:
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-15-2011, 06:30 PM   #14
hotrodhomi
hotrodhomi's Avatar
how much lower will that make the rear compared to the stock cross- member? Also, is there anything else that needs to be changed if the x-member was swapped besides the bigger notch?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 02-15-2011, 06:43 PM   #15
PBFAB.COM
PBFAB.COM's Avatar
Neither crossmember will lower the truck just by bolting it in place. But what it does is give adjustability to the fore-aft location and also the height of the front mounting points.
The advantage to this is being able to move the axle rearward, centering it in the aheel well opening. The adjustable mounting points for the front pivot of the trailing arms allows you to move the front pivot point higher, changing the instant center of the rear suspension.
The two-piece drive-shaft version does give more clearance as its lowest point is higher than the bottom of the frame-rails.
In order to actually lower the truck, a notch will be necessary. This trailing arm crossmember just allows some tuning ability to a lowered rear suspension.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-15-2011, 06:44 PM   #16
PBFAB.COM
PBFAB.COM's Avatar
Other mods may or may not be necessary depending on how low you want to get.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
