Old 02-15-2011, 05:37 PM   #1
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: Project BACK IN BLACK
Originally Posted by Tx Firefighter View Post
All that fresh metal and new paint work must have been pretty heavy. It looks like it lowered the truck about 3 inches in the front and 4 in the back.
There was a LOT of rust.
Originally Posted by franky69c10 View Post
Looks real good, any info on the drop u have and what size of tires r u running
It's got 2.5" spindles up front and 1 coil cut off the stock springs. Out back is shackles and hangers with the stock leafs. The tires are 275/60/15 front and back.
Originally Posted by JuicyJ View Post
Wow that is a good thrash. Looks good. Where did you get the doors from?
I got the doors and the bed from member lolife99.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 02-15-2011, 05:49 PM   #2
swb85
swb85's Avatar
I had kinda forgotten to update this thread....whoops! I'll do a better job.
I did get the bedliner sprayed in before winter hit. I ended up using Southern Polyurethanes again for the materials and am thrilled with how it turned out. Cost me 3x less than a professional would have charged.
I also got new seat upholstery for Christmas and I got a chance to put it in a few weeks ago. That was waaaaay more painful of a process than I ever imagined! It didn't turn out perfect, but good enough for a driver. Next time I'll be dropping it off at the upholstery shop and writing a check.
Before:
After: (crappy pic through a dirty window)
Old 02-17-2011, 06:40 AM   #3
franky69c10
chevy runs deep
franky69c10's Avatar
What shackles and hangers R u using
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 02-17-2011, 09:38 AM   #4
swb85
swb85's Avatar
Originally Posted by Pyro View Post
So why did you decided to go with satin black instead of gloss? How's the upkeep on it?
My truck sits outside 24/7, so I decided I didn't want to spend a ton of money on a paint job until I have another garage or a shop to park it in, but I needed to fix the rust before it got to the point where the truck wasn't worth fixing. I wasn't really sure how I'd like the satin black, as I'm usually not one to follow the latest fad......but I'm really digging it! It's been very durable so far, and upkeep is no different than any other black vehicle I've owned....dust shows up instantly, but it's quite a bit less noticeable than on gloss!
They are Summit brand.
http://www.summitracing.com/parts/SUM-G752/
