Closed Thread
Old 02-15-2011, 11:01 PM   #1676
67_ShortFleet
67_ShortFleet's Avatar
Re: What did you do to your truck today!
Well I looked for my new hinge pins and bushings for about an hour and a half. I think I remember putting them somewhere sothey would not get lost. I am about ready to just order another set.
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline
Old 02-16-2011, 12:10 AM   #1677
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Finally bent up a nice clean lookin' 3/8" hard fuel line for the small block in the '72 GMC. I'm pretty happy with the results.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
GASoline71 is offline
Old 02-16-2011, 08:01 AM   #1678
project 67 sub
project 67 sub's Avatar
cut out the top of the spring pocket on the passanger side, painted it all, and installed the plate, bag, fitting, and line. then i put the upper a arm back on. i also installed some heater hose around it for more protection of the air line, then i started running the air line inside through the side of the fire wall behind the fender, then i installed that fender and painted it green to match the rest of the burb. also had to take the drivers side fender back off so i can start on that side.
project 67 sub is offline
Old 02-16-2011, 08:02 AM   #1679
project 67 sub
Old 02-16-2011, 09:56 AM   #1680
mmmBoost
Didn't get anything done on my truck but, my all night project of replacing all my front brake calipers, pads, rotors, and flushing the old brake fluid out. The reason I did all this they updated the calipers finally so they won't warp the rotors anymore.
Yesterday i get 1 of my 4 tires for my jeep that I have to put on before I leave. The other three some how were a day behind the first. So I go down to the UPS Hub here and I'm hoping that they will let me get my other three tires instead of waiting all day for them to deliver them. To my surprise when I walk to a guy in an opening of a back in dock for the trailer when I asked him he told me to come on in the side door and he try to track them down and give them to me. I walk in and there they are sitting on the platform getting ready to be put in the delivery truck. He scans them and I was good to go. All this so I can go to Wisconsin to see family for a week today. Now I'm off to mount and balance my tires before packing up my jeep and heading out of town.
I do like these new tires though. Fierce Attitude M/T
A little more meat is never a bad thing
Big thanks to the guys down at the UPS Hub. Thanks again made my day a whole less stressful.
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline
Old 02-17-2011, 02:48 AM   #1681
project 67 sub
pulled the drivers side apart, drilled some holes so i can do some cutting tomorrow, and purchased some outer tie rods.
Old 02-17-2011, 07:01 AM   #1682
NINERS1
NINERS1's Avatar
Replaced my headlight knob, replaced my cargo light assy. replaced brake,gas and emergency brake pedal's.
71 chevy cheyenne lwb
http://s321.photobucket.com/albums/n..._tab_my_albums
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!
NINERS1 is offline
Old 02-19-2011, 08:28 PM   #1683
67Slider
67Slider's Avatar
Ground and drilled the rivets that held the original brake drums on the front of my 67. Went to Autozone and picked up some 67 brake shoes. Went to the junk yard and picked up front sway bar for $30, then went home to start on the brakes. Come to find out the 67 is an early model and GM was still using up the 66 parts. My front pads have to be 66 because the 67 pads are way too big. Took the 67 pads back with my old pads and sure enough... they were 66 pads. Luckily the drums are the same model cause I bought two of those too. Done for the day. I will finish up the front brake install tomorrow and begin reconditioning the front sway bar.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 02-19-2011, 08:32 PM   #1684
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Watched/helped hubscrub cut patches for his truckbed from my junk bed I had. Took some drums/wheels off a 5 lug rearend, debating to scrap it or not.
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 02-19-2011, 09:26 PM   #1685
bollybib
bollybib's Avatar
I installed new mirrors and arms, inside door handles and escutcheons, and brake pedal pad. I aligned the wiper arms and replaced a window regulator roller so the passenger window rolls up and down now.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline
Old 02-19-2011, 09:31 PM   #1686
Red68
Red68's Avatar
Took out my drive shaft since it came apart this week. Luckly I just started out from a stoplight and when I heard a loud pop I pulled over, so no damage to the truck. Just a broke yoke.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline
Old 02-19-2011, 10:58 PM   #1687
glider_6969
I decided to upgrade the look and add some gauges to my dash. I did the white gauge thing, It came out better than I thought, I just need to find one more gauge for the left side of the panel, not sure what I would put there yet.
Before,Name:  gauges 002.jpg
After,
68 Long stepper
My other ride ,,, 07 Streetglide..
glider_6969 is offline
Old 02-20-2011, 01:01 AM   #1688
ItsRandy
ItsRandy's Avatar
Reassembled my front suspension...sure is hard to put that stuff back together without scratching it!
ItsRandy is offline
Old 02-20-2011, 01:09 AM   #1689
67chevy1series
67chevy1series's Avatar
Before,Attachment 702178
how did you get the white face for guages?
After,
Attachment 702170
Attachment 702171
Attachment 702172
67chevy1series is offline
Old 02-20-2011, 01:12 AM   #1690
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
I replaced my power booster today. I thought that I was stopping well enough before now. So a new one of those and master cylinder I need to get use to the 'new' brakes in the ol' girl.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline
Old 02-20-2011, 02:58 PM   #1691
Sinister
Between Trucks...
Sinister's Avatar
Did my front brakes. I hate doing drum brakes. Have to do the rear ones in a little bit too.
Beat it to fit,
Paint it to match...
Sinister is offline
Old 02-20-2011, 05:58 PM   #1692
67Slider
67Slider's Avatar
I hear ya. Finished my fronts this morning too. PITA!!! Rears will be next month when the funds are a little better.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 02-20-2011, 08:06 PM   #1693
cpisani70@aol.com
cpisani70@aol.com's Avatar
Tried to figure out my engine brackets so I can get my ps pump mounted to my engine and whether I need to move my alt to the passenger side
cpisani70@aol.com is offline
Old 02-20-2011, 08:54 PM   #1694
glider_6969
I ordered them from this company-> whitegauges.net , they mailed them right to my door, and I live in Canada. They are an overlay decal real easy to do.
68 Long stepper
Old 02-20-2011, 09:04 PM   #1695
(joey)
(joey)'s Avatar
started my installation of the 01 sierra gauges into the 67.also stripped most of the interior of the sierra and started sorting miles of wires into what i need and what i dont.
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline
Old 02-20-2011, 10:46 PM   #1696
jakeblues652
jakeblues652's Avatar
(joey), do you have any idea what you are going to hide that in the dash with? and good luck with the wires. looks like you'll need it!!
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline
Old 02-20-2011, 11:10 PM   #1697
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
fixed my left turn signal indicator, OK I didn't fix it, but it hasn't worked in 5 years and today decides to start..
I did run a quarter tank of gas through it
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline
Old 02-20-2011, 11:25 PM   #1698
AirSpeed
AirSpeed's Avatar
You must be glad you won't be using all those wires! That would suck! Are you going to use steel to shape the area around the gauges or part of the Sierra dash?
AirSpeed is offline
Old 02-21-2011, 12:06 AM   #1699
Hubscrub
Cruzin
Hubscrub's Avatar
stripped the upper end of my steering column for paint and a new turnsignal switch. Man these trucks are soo simple compared to the new crap.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline
Old 02-21-2011, 12:23 AM   #1700
Dano69c10
Dano69c10's Avatar
Changed the motor mounts in my 70. What a gigantic PITA!
Hope to get the headers and exhaust system in tomorrow and get it to the shop so they can work on my tranny and brakes. Hope to have it ready for the Legends Get-Together next Sunday.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline
Closed Thread
