Old 02-09-2011, 11:31 AM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Show me your automatic floor shifters!!
Im thinking about moving my column shift to the floor and want to see what you guys have done.
Im running a bench seat and plan to keep it that way. My daughter usually rides with us to shows.
Thanks guys!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-09-2011, 11:56 AM   #2
smilts60
Re: Show me your automatic floor shifters!!
Heres what I'm pulling out of my truck its pretty ghetto. I think with a little more work it could have been much nicer
smilts60 is offline   Reply With Quote
Old 02-09-2011, 12:38 PM   #3
jchav62
1962 C-10
jchav62's Avatar
Lokar 16" floor mount...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 02-09-2011, 01:10 PM   #4
PGSigns
PGSigns's Avatar
This thread is right on time. I am looking at the lokars to replace the B&M that is on the floor now for a more retro look and that one is just what I am wanting. Hows it working out?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-09-2011, 01:14 PM   #5
jchav62
1962 C-10
jchav62's Avatar
Jimmy
It works great. The throw is a little long but we are getting used to it...
Joseph Chavez
Old 02-09-2011, 01:32 PM   #6
61_FL_Apache
Who Me?
Is it centered with the seat? Is it also cable driven? I was thinking about one like this, but I want to mount it as far left on the hump as I can so its not in the way of the person in the middle.
Steve
2001 Blazer 4D 2WD
Old 02-09-2011, 01:32 PM   #7
PGSigns
PGSigns's Avatar
Thanks for the info. That is going on my list, and that gets longer everyday.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 02-09-2011, 02:13 PM   #8
61_FL_Apache
Who Me?
I see you still have the one on the column. Are you going to keep that one? I was thinking about shaving and filling where it came from if I go to the floor.
Steve
2001 Blazer 4D 2WD
Old 02-09-2011, 04:22 PM   #9
jchav62
1962 C-10
jchav62's Avatar
It's not there any more. I've since changed out that column to a '4 speed' type column. I changed that out at the same time I did the power steering conversion...
Joseph Chavez
Old 02-09-2011, 06:24 PM   #10
awbrown
I think mine is from the 60's it is a Mr.Gasket , long like the lokar , but no detents ... my last truck that I converted had a tire iron mounted to a slice of angle iron bolted to the floor , it worked well ....
awbrown is offline   Reply With Quote
Old 02-10-2011, 09:44 AM   #11
61_FL_Apache
Who Me?
Im all for fabbing something up too. I had a long chain welded together in my 65 with a nasty looking piston on top.
Steve
2001 Blazer 4D 2WD
Old 02-10-2011, 10:04 AM   #12
awbrown
I may get a tire iron chromed and do it again for one of my trucks , but I need to incorperate some detents so I may have to find a shifter that I can modify ,just ad the tire iron to it .....
Old 02-12-2011, 09:18 PM   #13
creep
Registered Loser
creep's Avatar
I put a B&M Unimatic in mine. It looks good and works decent. I had to put spacers under the front mounting flanges so the cable clears the lip of the hump cover opening. With the boot on you can't tell though.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 02-12-2011, 11:11 PM   #14
markeb01
Senior Enthusiast
markeb01's Avatar
I’ve had both Gennie and Lokar shifters. I preferred the Gennie since knobs could be changed at will, there was no button to rattle and it was as easy to use as a column shifter.
Here are a few lousy pictures of my GMC with both shifters. The first is the 23” Lokar. I wanted a Gennie shifter because I loved the one I had in my 46 Ford. Unfortunately I went with the Lokar because Gennie didn’t have an adjustable mount yet, and I wanted the handle to come to come through the original hole in the floor pan, and to the casual observer it looked just like the original 4 speed handle.
Mine was the linkage type. Here’s what it looked like on the transmission:
As soon as Gennie introduced an adjustable mount the Lokar was pitched in the garbage and was replaced with a Gennie Shifter. I went with the 16” length because by then I had tired of the long handle. It remained in place for over a decade until I swapped back to a Richmond 4 speed:
The Lokar was in the truck about a year and I grew to hate it. They may have changed the design since I had mine, but the knob rattled constantly and was really irritating. Worse, in temperatures below freezing the grease in the handle froze up, immobilizing the knob, preventing the use of my daily driver. The solution was to run a complete can of WD40 down the shaft to rinse out the grease. After that the rattling absolutely drove me crazy. And if the thumb wasn’t centered on the knob, it was also easy to painfully fold back a thumbnail when depressing the button. I also didn’t like that only a Lokar knob could be used, although a knob adapter was made available after I got rid of mine. I have no experience in how well these work.
One benefit of the Lokar shifter is the locking feature allows the shifter to go between neutral and drive with no risk of overshooting into reverse. Both brands are well made and function well if you like their specific features. Although both shifters mount on the transmission centerline, I believe the Lokar handle can be rotated toward the driver.
One area Lokar has it all over Gennie is in the sales distribution. Everybody carries Lokar. The last time I checked, the only place to get favorable pricing on Gennie was through Chevy of the 40’s.
Old 02-12-2011, 11:34 PM   #15
coolair
Heres my Lokar shifter.....
Name:  marks pics 476.jpg
coolair is offline   Reply With Quote
Old 02-14-2011, 08:55 AM   #16
hotrodimpy
markeb01. We here at Lokar are sorry you were so unhappy with your Lokar product.
We do have a tech department here at Lokar that is here to help with any issues that one might have. We did have a problem with a grease we were using. That was many years ago. and we have corrected that issue. As for the rattling problem. That is also a simple fix, it is in the adjustment of the shifter and is no problem to stop. Lokar is here to help anytime a customer has a problem. We cannot help if we are not made awhere of these problems. Anytime you or any customer has a problem PLEASE contact us here at Lokar Performance Products Toll Free 877-469-7440
hotrodimpy is offline   Reply With Quote
Old 02-14-2011, 09:13 AM   #17
lakeroadster
I see you still have the one on the column. ......... I was thinking about shaving and filling where it came from if I go to the floor.
You can buy an original column bonnet from a floor shifted truck that doesn't have the column shift, that's what I did. You will need to pull the column to install it.
lakeroadster is offline   Reply With Quote
Old 02-14-2011, 09:33 AM   #18
61_FL_Apache
Who Me?
lakeroadster, that looks real good!!
Steve
2001 Blazer 4D 2WD
Old 02-16-2011, 12:14 AM   #19
gringoloco
A guy with a truck
gringoloco's Avatar
Is yours mounted above or below the floor?
Looks good!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
