Old 02-14-2011, 02:10 AM   #1
franky69c10
chevy runs deep
franky69c10's Avatar
Unhappy Need help ASAP idk what 2 do next
Truck dont wanna start wanna know if u guys can help me out ok I have a 87 R10 Silverado with a 350 5.7 TBI , I started the truck 2 move it in the shade it ran fine b4 the tune up so I bought new plugs, wires, cap and rotor, fuel filter, oil filter and oil, so I got down drain the oil put and all the new stuff in and new fuel filter in also then I started on the plugs did the all the gaps right put the cap and rotor on next was the wires did the firing order right then I go 2 start it it won't start just keeps turning over I'm getting fuel and spark right now I'm stuck like chuck idk what 2 check out next, just wanna know if guys had this problem and how 2 fix this....
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 02-14-2011, 02:24 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Need help ASAP idk what 2 do next
Pour a little fuel down the TB. Does it run for a few seconds? If so you have a fuel pressure problem. TBI's are very sensitive to fuel pressure loss.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-14-2011, 02:25 AM   #3
BigRed76
BigRed76's Avatar
If you have spark and fuel then I would say check your firing order again, or maybe somehow your timing got messed with during all the work you did.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 02-14-2011, 02:37 AM   #4
franky69c10
chevy runs deep
Thanks guys gonna check it out 2 morrow could air get into the fuel lines when I changed out the fuel filter And that's what causing not 2 start
RAIDER NATION
My LWB is a SWB now
Old 02-14-2011, 08:29 AM   #5
BigBlocksRule
Air in the line shouldn't be a problem, the regulator sends excess fuel back through the return line and that should purge the line.
Check your ignition - you probably have something wrong. You swapped a lot of stuff, there's plenty of room for error.
BigBlocksRule is offline   Reply With Quote
Old 02-14-2011, 10:02 AM   #6
allengator
allengator's Avatar
+1... and why I do plug wires one at a time
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 02-15-2011, 09:41 PM   #7
4x4toy
Did you put oil back in it? Fuel pump wont turn on until oil pressure switch has pressure on it.
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 02-16-2011, 04:47 AM   #8
franky69c10
chevy runs deep
Yeah that was the first thing I did was change the oil, when I got off work 2 day I messed with it but no luck should I check the oil pressure switch
RAIDER NATION
My LWB is a SWB now
Old 02-16-2011, 05:03 AM   #9
franky69c10
chevy runs deep
And where is the oil pressure switch located
RAIDER NATION
My LWB is a SWB now
Old 02-16-2011, 12:05 PM   #10
psuedopimp
psuedopimp's Avatar
i would tripple check your plug wires. did you plug your distributor back in?
psuedopimp is offline   Reply With Quote
Old 02-16-2011, 04:55 PM   #11
franky69c10
chevy runs deep
Got it running
RAIDER NATION
My LWB is a SWB now
Old 02-16-2011, 04:57 PM   #12
psuedopimp
psuedopimp's Avatar
what was the solution?
Old 02-16-2011, 05:08 PM   #13
franky69c10
chevy runs deep
wires
RAIDER NATION
My LWB is a SWB now
Old 02-16-2011, 05:10 PM   #14
psuedopimp
psuedopimp's Avatar
at least the fix was free.
