Old 02-16-2011, 11:54 PM   #1
jeffmoyer80
Post how much paint do i need
i have a 66 gmc flat bed truck. i want to repaint the cab of the truck., i sure can use some help so i can order the paint., i want it light blue and white., thxs jeff
jeffmoyer80 is offline   Reply With Quote
Old 02-17-2011, 02:24 AM   #2
jimmydean
jimmydean's Avatar
Re: how much paint to i need
A lot depends on the paint you are using and how many coats you want to put on to get the look you are shooting for. If you are ordering the paint from a good shop, they should be able to give you a good estimate.
My '69 took about 8 cans.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-17-2011, 05:52 AM   #3
jj1965
jj1965's Avatar
Painting my truck I used a gallon of color for two coats, but I had the bed to paint. Depends upon the color of the paint and how much reducer and or hardner it uses. My paint was a 2:1 mix so it was 1.5 gallons when reduced. Some colors will cover in two coats some take three. I agree with the post above, talk to the paint shop before you make a decision. Better a little extra than not enough.
jj1965 is offline   Reply With Quote
Old 02-17-2011, 08:12 AM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
A lot would depend on color for coverage. Are you doing single stage paint or using clear?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
