Old 02-17-2011, 12:11 PM   #601
FL71C10
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
That's ok, they'd probably be too hard to find elements for anyway.
Originally Posted by drewskiren View Post
Not to rub it in, but I do have a rather nice collection of these extremely rare low profile air cleaners. No they are not for sale!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 02-17-2011, 12:12 PM   #602
67cheby
67cheby
67cheby's Avatar
Lol
67cheby is offline   Reply With Quote
Old 02-17-2011, 12:57 PM   #603
VA72C10
VA72C10
VA72C10's Avatar
I like the air cleaner.....the chip versions are super hard to find as they add at least 5rwhp due to the grease that is scavenged from the sides...
Old 02-17-2011, 01:10 PM   #604
68 TT
Still plays with trucks
68 TT's Avatar
I am thinking I will pull all the wiring out with the motor and set the motor in the new frame and I might even try to rig up a battery and start the thing before I make any modifications to the harness. I have already pulled out the ignition cylinder and am able to plug it into my other truck's wiring block and start it with it, so I won't have to have the column sitting in the floor.
If you can get that ignition switch mounted in the dash and keep the whole VATS system functional that would be a nice bonus.
I was working on a replacement lever for the column mounted wiper control stalk so you could mount it behind the dash and the knob would look somewhat like a stock older Chevy wiper control knob. I lost my access to a lathe so things have come to a halt for now. I need to pick up another lathe for at home.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 02-17-2011, 02:14 PM   #605
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Yes, I am trying to keep the Passlock system and plan on mounting the existing switch somewhere. I would love an old looking solution to my cruise control stalk. I don't even care if it is full function, just on, off and set.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 02-17-2011, 03:22 PM   #606
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
****another reader of the entire post in one day!***** You do very good work and I can only hope to have half the skills som eday! Cheers to you from Michigan
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 02-17-2011, 03:51 PM   #607
68 TT
68 TT's Avatar
Yes, I am trying to keep the VATS and plan on mounting the existing switch somewhere. I would love an old looking solution to my cruise control stalk. I don't even car if it is full function, just on, off and set.
I was only concerned with getting the delay wiper controls out of it but with just a little more complexity it could be made to incorporate the cruise control features as well. It would probably only add an inch to the depth of the wiper knob to make it do both functions.
I would have to tear a cruise control switch control stalk apart and see how it works. It might be possible to reuse the speed set button and on / off / resume slider from the donor in an aluminum knob assembly that ran the wipers too.
If I still had access to solid works I could play around with it some. Not quite as easy now with just regular old AutoCAD solids modeling. Once I get that far on my 69 C20 I will get back into that again.
You could put a square body steering column in there and use the cruise & wiper controls from that vintage. I am half way through doing that conversion to my 67 C10. It is not too obvious of a change that it would look out of place in an otherwise stock 67-72 truck interior with the original steering wheel installed onto it.
Old 02-18-2011, 10:09 PM   #608
drewskiren
drewskiren's Avatar
Thanks, and I am honored you took the time to read it all.
Drew
Old 02-18-2011, 10:29 PM   #609
drewskiren
drewskiren's Avatar
I did at least get my axle pulled from the donor truck. I have taken it to get reworked and it might come back powdercoated?!?
Drew
Old 02-19-2011, 01:15 AM   #610
wwhijr
SUPERscrapMAN
wwhijr's Avatar
I had a 77 (i think) Bonneville that just had a button in the end of the turn signal stalk. Might look better than the multi function.
Christine 1987 Chevy S10 2.8l 5 speed 600k miles! still chugging along - wifes ride
Old Smokey 1990 Chevy K1500 Suburban 6.2L Diesel - Banks sidewinder
The WarBeast 1994 Chevy Suburban K1500 - Semi retired at 400K miles
The BLueOx 1994 Chevy Suburban. K2500 454 Used on a daily basis.
wwhijr is offline   Reply With Quote
Old 02-19-2011, 10:09 AM   #611
JasonBird
'67 C-10 LWB Driver
JasonBird's Avatar
lol...that wiring is scary looking...now i remember why i wanted an old truck!
'67 C-10 LWB - My Build Thread
'67 C-20 LWB - My Donor/ Parts truck - SOLD!
'92 GMC SAFARI VAN - My Parts Go Getter
'06 KIA SPORTAGE EX - My Commuter
"All of this crap better make a truck!" - my wife Sue.
Proud U.S.M.C. Dad!
JasonBird is offline   Reply With Quote
Old 02-19-2011, 12:23 PM   #612
drewskiren
drewskiren's Avatar
I will be methodically stripping this down and showing what I did for anyone interested.
Drew
Old 02-19-2011, 04:18 PM   #613
(joey)
(joey)'s Avatar
count me in.im very interested.started stripping apart the sierra today so this is perfect timing
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline   Reply With Quote
Old 02-20-2011, 10:42 PM   #614
drewskiren
drewskiren's Avatar
I finally got the rest of my suspension system, the front Coolride from Ride Tech. I also ordered the Firestone F9000 sleeve type bags for the rear which ride very smooth since I have the room to fit them. I'll be selling the 4 other Firestone double convoluted bags that came with the half price kit I bought from another members failed project.
Now I can't decide what to do next: engine and wiring or suspension system.
Drew
Old 02-20-2011, 10:50 PM   #615
VA72C10
VA72C10
VA72C10's Avatar
Both
Old 02-20-2011, 10:51 PM   #616
drewskiren
drewskiren's Avatar
Originally Posted by VA72C10 View Post
Both
When are you arriving to help?????
Drew
Old 02-20-2011, 11:22 PM   #617
VA72C10
VA72C10
VA72C10's Avatar
Right after you come over here to help on my new build
Old 02-20-2011, 11:25 PM   #618
drewskiren
drewskiren's Avatar
Wish you had told me, I was in Chapel Hill visiting UNC and Duke with my son all weekend. Could have swung up and knocked it out.
Drew
Old 02-21-2011, 06:12 PM   #619
drewskiren
drewskiren's Avatar
Working my plan for not cutting a single wire! Dash of new truck is completely out as well as column. The only problem I was going to have was keeping the fuse panel intact, but still fitting it through the firewall hole. Hmmmm. Solution: Cut out firewall and take it with me ! Ha! Fixed your wagon.
Now that I have had that revelation, I will probably cut out my old firewall and weld this one in with the waterproof grommet already installed.
Drew
Old 02-21-2011, 06:37 PM   #620
67cheby
67cheby
67cheby's Avatar
Confucious say .....BRILLIANT
Old 02-21-2011, 07:48 PM   #621
propanemudtruck
How many pounds of wire do you have there???
-Kevin
Old 02-21-2011, 09:09 PM   #622
drewskiren
drewskiren's Avatar
I'll guess about 40.
On another note, I'm kinda frustrated with Ride Tech right now. The parts list shows some hardware being marked off of my kit like I don't need it, but I do. What the heck? I can't work on the front setup now because I'm missing parts - on purpose !
Drew
Old 02-21-2011, 10:49 PM   #623
drewskiren
drewskiren's Avatar
Here is the parts sheet with items crossed off???
I was able to mock it up and see how it works/set my ride height.
Drew
Old 02-21-2011, 10:53 PM   #624
VA72C10
VA72C10
VA72C10's Avatar
nice progress...I admire you getting a little done almost daily if not daily. I am trying to do the same on my new build
That's weird they crossed the items off...maybe they were backordered but forgot to tell you???? Still stinks...
Old 02-21-2011, 11:07 PM   #625
Rokcrln
Rokcrln's Avatar
Drew you are making good progress and yes I love the shop!
Here are the holes I did for the cold air intake and with the grill back on they do not show at all. Should be plenty of air for these motors. Sorry but my battery died in my camera after this shot.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
