![]() Join Date: Jul 2002
Hey fellas....picked up a Dana 60 rear out of a 72 3/4 ton 2 wheel drive C-20.....it's an open rear, but it's got 4.10's that I wanted to put under my 72 K-5. Are the spring perches the same width, or will I have to weld new ones in? Thanks.....
Patch |
user # 2756
![]() Join Date: Jun 2001
Will be the same. But if you have both go ahead and measure. The 3/4 and 1 ton leaf frames are supposedly the same as the K series in regards to width.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
I am not so sure that the widths are the same. I put a D60 out of a 72' 2wd 3/4 ton into a 69 3/4 4x4 and the 2wd had wider perches by about 2".
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
Yup, 2" difference. UNLESS it was a Longhorn. Longhorns and 4x4 have 40.5" centers, same as a Blazer, but the 2 wheel drive leaf trucks have 42.5" centers. I have a Longhorn 60 that will eventually wind up in my Jimmy.
