Old 02-20-2011, 09:20 PM   #1
justinburnett
justinburnett's Avatar
Engine swap
Truck is a 1973 K20. Engine is from a 1987 Blazer (I think). Both 350, both carb'd, I don't know that the newer one really is a 1987 but it does have center bolt valve covers and a 1pc rear main. It doesn't seem to have any electronics though. What problems will I run into trying to put the blazer engine in my truck? I need this thing to be running in 13 days max. Thanks.
justinburnett is offline   Reply With Quote
Old 02-20-2011, 09:36 PM   #2
Toxic Redline
Toxic Redline's Avatar
Re: Engine swap
its the little stuff like wiring and vacuum/gas/emmisions lines that might hold you back, i think it should be pretty straight forward, i put a rebuild 70 350 in my 84 with no problem execpt me forgeting where wiring went. just a suggestion but label wires and take pictures during the tear down just to be on the safe side.. put the motor mounts off the 73 on the motor
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
Old 02-20-2011, 09:48 PM   #3
justinburnett
Re: Engine swap
I figured the mounts would be the same but it makes sense since I know the old ones fit. Thbanks, and my camera is standing by.
Old 02-20-2011, 10:39 PM   #4
bmchevy1979
bmchevy1979's Avatar
Re: Engine swap
you need the correct flywheel/flexplate for the 1pc motor and as stated above keep good track of everything
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 02-21-2011, 12:10 PM   #5
justinburnett
Re: Engine swap
came with a flexplate already attached. Going to change out the rear main though, since it'd be a shame to put it in and have it start blowing oil out the backside in 100 miles and have to pull it again.
Old 02-21-2011, 01:48 PM   #6
MARKDTN
Re: Engine swap
If you swap it complete with intake and flexplate you should not have any issues. Mounts are the same, exhaust is the same, accessory holes in the heads are the same. The main differences in these are the 1-pc rear seal that changes the flexplate and the center-bolt heads that changes the intake. The dipstick changing sides should no affect much.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 02-21-2011, 04:55 PM   #7
justinburnett
Re: Engine swap
Cool cool. Looking forward to it (except the weather). thought it was going to warm up but now they're calling for snow tomorrow-sunday
Old 02-22-2011, 01:55 AM   #8
justinburnett
Re: Engine swap
Does anyone know what bolts I need for the fuel pump? They seem to b e missing. Thanks.
Old 02-22-2011, 08:33 AM   #9
MARKDTN
Re: Engine swap
Use off you old engine. If the '87 engine started life as a TBI engine it may not be drilled for a fuel pump rod. Thought you said both were carbed?
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 02-22-2011, 05:40 PM   #10
justinburnett
Re: Engine swap
Yes both of them are carbed. The fuel pump looks the same but I wasn't sure if the newer one would be metric or not.
