Old 02-15-2011, 02:12 PM   #1
Teech
63 GMC Closed Knuckle D44F Swap to open knuckle?
Hi Folks,
Does anyone know if there are years of front open-knuckle D44s on Chevrolet or GMC trucks that will swap with my current closed-knuckle on my 63 GMC 3/4T 4x4 without cutting/welding etc.? Is there a straight bolt-on swap out there? If so, what years/models might they be? Thanks!!
Teech is offline   Reply With Quote
Old 02-16-2011, 01:28 AM   #2
'63GENIII
'63GENIII's Avatar
Re: 63 GMC Closed Knuckle D44F Swap to open knuckle?
I picked mine up from a '72 3/4 ton. It was an easy swap even though I went from 1/2 ton to 3/4 ton. I think I remember brake lines being an issue.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 02-16-2011, 08:42 AM   #3
duallyjams
duallyjams's Avatar
You can use a axle up to 1987 and it will bolt in. When you go from drum to disc brakes that is the big change as ie brake lines,master cylinder, ect.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-16-2011, 10:20 AM   #4
Teech
Thanks guys. Up to '87: Good to know! I'm prepared for all the mods to switch to discs...I don't have the parts yet, but I know what's in store. Thanks again.
Old 02-21-2011, 12:53 AM   #5
jerry moss
Born Psycho
jerry moss's Avatar
axle is a bolt in swap, brake lines are definitly different and the steering will be a lot different. we used a 72 p-s box on my nephew's 63. had to modify the column and space the box away from the frame. not a big problem but took a little time to get everything right. he's put well over 100K on that truck since we built it several years ago.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 02-23-2011, 10:50 AM   #6
Teech
Thanks Jerry. Fortune has smiled on me: the truck already has later model power steering! I'm doing a complete (mostly) rebuild, so the brake lines should be no problem. 100K miles on your rebuild? That's great...I hope to do the same. Thanks again.
