Old 02-21-2011, 07:36 AM   #1
1984 t type
Any 3/4 ton with 4"-6" lift pictures
I'm thinking of lifting my truck and would like to see some pictures of similar trucks with 4"-6" suspension lifts. Also how tuff of a job is this to do in the driveway, does it take any speical tools?
1987 Buick Grand National
2018 Road Glide Special
1984 t type is offline   Reply With Quote
Old 02-21-2011, 10:41 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Any 3/4 ton with 4"-6" lift pictures
You can lift up to 3" and be good with the stock brake lines and pitman arm. At 4" of lift, you might be able to get away with leaving those items stock but really shouldn't. At 6", longer brake lines and dropped pitman arm are a must. Plus getting the driveshafts lengthened.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-21-2011, 10:45 AM   #3
1984 t type
Ok thanks , I will prob go with the 4" tuff country ez ride kit. It comes with the brake lines and steering arm I believe. Can I ride 35" tires with a 4" lift ?
Old 02-21-2011, 10:57 AM   #4
cochino12
It followed me home?
cochino12's Avatar
depends on where you want to drive it. If its mainly a street truck then 4" is fine but it you wheel it a lot I would stick with 33"s or a 6" and 35"s
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-21-2011, 11:02 AM   #5
1984 t type
I don't off road just love the room that suburbans offer and you can't beat it in the looks department either, also needed something that can push it's way through a foot of snow
Old 02-21-2011, 11:10 AM   #6
68Timber
68Timber's Avatar
4" of lift over 35's looks great and will run offroad very well in the mild to moderate stuff.
John
74 Honda Z50 build
Old 02-21-2011, 11:25 AM   #7
1984 t type
What about the body lifts or lift blocks, what kind of ride do they offer? I don't want a rough ride
Old 02-21-2011, 11:36 AM   #8
68Timber
68Timber's Avatar
The body lifts won't change the ride, they just pick the body up off the frame further for more tire clearance.
A spring lift will not necessarily ride rough. Even though the spring rates may be higher they'll feel better on the road just getting rid of the tired originals.
John
74 Honda Z50 build
Old 02-21-2011, 11:49 AM   #9
1984 t type
I see a 3" body lift kit that's prety cheap compared to the 4" suspension. What size tires can I ride with a 3" body lift ( I have 31's now )
Old 02-21-2011, 01:16 PM   #10
68Timber
68Timber's Avatar
You should be able to run 33's with a 3" body lift. I gotta tell you, I don't know much about them except how they work. When you increase the distance between the body and frame, you're changing more than you think. The steering column is firewall mounted but the steering box is mounted on the frame - you have to watch for stress on that rag joint. The engine and fan are mounted on the frame but the radiator and fan shroud are mounted to the body so you have to watch that the fan doesn't make contact with the bottom of the fan shroud. There may be issues with your transfer case shift linkage, maybe not. Things like that have to be taken into consideration. Then there's the cosmetic issue. The bumpers are mounted to the frame and when you move the body up, the gap gets noticeably bigger. It's something you'll notice in the wheel wells as well.
That kind of stuff might not bother you. To me, a spring lift with new shocks is simple and just "right".
John
74 Honda Z50 build
Old 02-21-2011, 01:19 PM   #11
1984 t type
Thanks I didn't think about any of that. Looks like I'm gonna just have to come off the cash for the suspension lift kit. I wanna do it once the right way
Old 02-21-2011, 08:21 PM   #12
JURKFASE
here is my 91 1 ton with a 6" alcan spring lift, and 37" BFG KM2'S
91 BURBAN 5/4 TON
6.2L BANKS SIDEWINDER TURBO DIESEL
6" ALCAN SPRING LIFT
14 BOLT FF REAR DETROIT LOCKED 4.56'S
DANA 60 FRONT 4.56'S
CROSSOVER STEERING WITH HYDRO ASSIST
BLAZEN FRONT BUMPER WITH 12K WARN WINCH
CUSTOM MADE REAR BUMPER WITH SWING AWAY TIRE CARRIER
37" BFG KM2'S
TOM WOODS CUSTOM DRIVESHAFTS
JURKFASE is offline   Reply With Quote
Old 02-23-2011, 06:23 PM   #13
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Couldn't have said it any better myself. Yes 4" lift will be fine with 35" tires for what you intend to use your truck for.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 02-24-2011, 04:36 PM   #14
LiveAnimals
LiveAnimals's Avatar
Im going to do a 4/35 combo. Here are some pics Ive saved
6/35
6/35
4 with 315/75 16s basically 35s
4/35
4/35
4/35
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 02-25-2011, 04:19 PM   #15
'91 w/4" Tuff Country EZ-Rides & 35s on 10" wheels. They rub when twisting so 8" wheels do better off road:
Old 02-25-2011, 04:22 PM   #16
Here it is again. I saved hese pictures when it was for sale. I really like that thing:
Old 03-03-2011, 03:23 AM   #17
Hotrodd 72
Here's my 84 with a 91 grill it is a 3/4 ton with 4" lift and 35's
Hotrodd 72 is offline   Reply With Quote
Old 03-03-2011, 12:04 PM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
I don't think you will find a better combo than this-
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-03-2011, 12:31 PM   #19
1984 t type
Yea that truck is bad ass !
