Old 02-20-2011, 05:38 AM   #1
mongoose
mongoose's Avatar
AOL Question...
I've got all my parts for an aol setup... about to mock it all up to drill out the holes... and i notice that the passenger side shock and the bag want to take up the same real estate... doh.. the dirver side is fine.. just the passenger side that is troublesome.
so people who have run this set up what did you do about the pass/ side shock... I was thinking of running a stud off the u bolt plate and running it backwards like the driver side.. pics always help too. Thanks.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 02-20-2011, 01:02 PM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: AOL Question...
That's what I would do.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-20-2011, 01:03 PM   #3
SCOTI
SCOTI's Avatar
Re: AOL Question...
Your options are to relocate the shock like you mentioned or stagger the air bag mounting locations to work w/the existing shock locations (one side in front of the rear, shock to the rear; other side behind the rear, shock to the front).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-20-2011, 04:57 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: AOL Question...
Bad pic, but this is how we did it...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-20-2011, 05:08 PM   #5
mongoose
mongoose's Avatar
Re: AOL Question...
did you cut the mount off the axle and reweld it?
need to go look at mine and see if a can turn the shock mount extender around.
Old 02-21-2011, 11:52 AM   #6
blazer2007
Re: AOL Question...
could you post pics as you go ,would like to know as well as others I,m sure
blazer2007 is offline   Reply With Quote
