![]() ![]() Join Date: Jan 2011
1969 C10 SWB - Big Block project
Here is my latest project, I thought you guys might like to follow along. I'll post more pics as we make more progress. I'm an old Camaro guy but I have always loved these trucks. Any year, there's just nothing like them. Camaros are fun too and I have restored several but they're just getting so expensive to build and 'numbers oriented' I got out of them. I'm just so tired of building my car the way it's supposed to be .. not how I want it to be, then having to listen to people tell me I'm wrong for building it that way. It takes all the fun out of it. Build it your way, what you like and what suits your personality. Bagged, or stock. I like them all.
![]() Check this one out. Frame off project, I bought it off a guy in KY. He just lost intrest in it apparently. This is my first C10 build but I am having a lot of fun with it already. All the difficult stuff is already done. the frame has been blasted and painted nicely, new cab corners, rockers, and mounts. The firewall has been cleaned up, floors fixed where necessary, etc. They did a very nice job with it. It is a great start to what will hopefully end up a nice old truck. I plan to paint it myself. 69 date coded 396/350 Cleaned and .030 over 10.5:1 69 dated '290' heads Lunati Bracket Master II cam MSD HEI 750cfm Holley 3310 Roller tip rockers, studs, guides Built TH400 2800 stall 73-87 front suspension swap Re-located gas tank with all new lines I'm working on changing it over to the 68 style front end. Things are likely to change of course. .. check back if you want. The 69-72 hood is also for sale if you know of anyone who might want it. Basically new from LMC. You guys rock. Thanks for all your help. Chad
Re: 1969 C10 SWB Stepside - Big Block project
just some more pics ..
The carb on it now is just on there to keep dust out of it. I know that's not a 3310.
NICE!!!!!! keep pictures coming & hey from N.C.
6>8 Plugless........
![]() Join Date: Sep 2007
Very nice truck and love that big block power!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Made some progress this weekend. The weather is about to turn around in the SE TN area, man, I can't wait for spring.
The Intake & Carb is just sitting on there to keep the dust and stuff out right now. The pass side valve cover will be ok I think, but the driver will need some tweaking to make it work and allow some breathing room. It's just barely touching the firewall. I'll re-shape that area a little and I think it will be fine. More to come. ..
It looks great in there! Good luck with the firewall tweaking.
Nice project there. Good luck with the build.
1972 GMC (PROJECT LONG OVERDUE) ![]() 1998 SWB 4WD |
wow that engine looks beast!
WOW! Now this is the way I would build my truck (when I get one).
![]() I am new to the site and have really loved these trucks from back in the day. My dad owned a 1967 longbed, and I can remember helping him change the water pump on that 6 cylinder. Probably my first mechanical repair. Good luck with that project. I will follow along!
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Looks great buddy! Nice work.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Still Learning
Looks like a great project you have. I'll follow along too.
My dad came up with a new center cap design.. check it out. I posted this to the threads for a few days but got a bit nervous when guys mentioned GM licensing, etc. So, I deleted it. I thought it would be ok to post in my build thread just so I could share it with you all. We never intended to build these for resale, we're just playing around to see what it would look like. I really like how it turned out.
Dad has also fitted the headers and dropped in the HEI. It's coming together. Now, if I could just find someone with a 68 RH front fender !
#15 |
More pics
#16 |
I will be changing the trim rings soon, they just don't sit flush with the wheel and almost makes the tire look too small. Humm.. I guess we'll see what happens.
It might get a nicer set of wheels when I can afford it and after paint..
#17 |
subscribed, I want to see where this goes.
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
#18 |
Just got done dropping my Cab from LWB on SWB doner frame...transfered k-member and posi rear. Fresh urethane cab mounts and t-arm bushings.
Plan to drop 69 427 (from my 67 Camaro - going bigger) Both are 4spds... What did you do for a driveshaft? One piece?? ![]() jmanders1@live.com |
#19 |
Actually, I haven't gotten a drive shaft yet .. good question. Is a one piece better you think? with a BB, would a 2 piece be more venerable? Not sure what I'm going with but I need to figure it out soon.
#20 |
Badass
1 pce drive shaft.. but nice build man. motor looks good!
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
#21 |
Grandpa in the rustmobile...
Build looks good neighbor (Mcminnville TN)! Whens she gonna hit the road, maybe I'll see ya at some cruise ins?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#22 |
Sure man .. I'd like to meet you sometime. I'll be around the swap meets and shows coming up this spring. I hope to have my truck on the road by late summer / fall.
#23 |
nice progress 69rat, sorry the fender didnt work out........
#24 |
What events will ya be attending (Your a lil bit east of me..but not far)
#25 |
born to lose
those center caps are legit homie!
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 ![]() '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 ![]() Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
