Old 02-22-2011, 03:45 PM   #1
remist17
remist17's Avatar
87 Rear Tail light issues -- Help
I purchased some new rear taillights for my 87 Chevy Stepside. The wiring must be all wrong since the brake light is now the reverse light and the running lights are not really bright.
I have three wires coming out of the bed... yellow, green and brown.
The wires from the lights (purchased at Classicparts.com) Ones Brown, white, and red.
Two are together and one is seperate. If any one can help me out with what wires go to what I would appreciate. I am looking for the wire id on the truck and I will figure out the lights.
2013 Chevy Silverado, Z71, 5.3L, 4 door
2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40
Support the Troops.
remist17 is offline   Reply With Quote
Old 02-22-2011, 04:24 PM   #2
psuedopimp
psuedopimp's Avatar
Re: 87 Rear Tail light issues -- Help
brown = tail lights
green = right turn
yellow = left turn
white = wire to common or chassis ground
psuedopimp is offline   Reply With Quote
Old 02-22-2011, 05:21 PM   #3
remist17
remist17's Avatar
Originally Posted by psuedopimp View Post
brown = tail lights
green = right turn
yellow = left turn
Can you tell me why I have the same Green, yellow, Brown on both sides?
No white from the truck just lights.
I am thinkg the driver side (yellow) is hooked up and the green is the ground? and the green is hooked up on psg side and the yellow would be ground?
What about reverse lights?
Support the Troops.
Old 02-22-2011, 05:49 PM   #4
psuedopimp
psuedopimp's Avatar
i am going by memory of hooking up trailer lights to be honest. i will try to remember to look at my tail lights and take a picture tonight.
Old 02-23-2011, 12:42 AM   #5
psuedopimp
psuedopimp's Avatar
here is a picture of my 84 drivers rear tail light
i tried to get a passenger side pic also but i had a screw rusted in there and didn't want to mess with it tonight.
my brakes turns haz and tail lights all work but i do not have reverse lights.
here is a pic of the small light wires, looks like brown and black.
here is a pic of the top bulb looks like yellow brown and black
here is a pic of the bottom bulb looks like green and black
hope this helps.
Old 02-23-2011, 10:27 AM   #6
remist17
remist17's Avatar
Thanks for the photos.
Looks like the photos are of a fleetside. Mine is a step with the external lights.
I am narrowing it down... but I only have 3 wires from the truck and 3 wires from the lamp.
Support the Troops.
Old 02-23-2011, 10:45 AM   #7
West Texas Z
El Mero Mero Frijolero!!
West Texas Z's Avatar
This my sound dumb to ask, but is your turn signal cam working? Mine was broke and my wiring was messed up. I replaced it and it fixed my rear light problem. Just a suggestion.
West Texas Z is offline   Reply With Quote
Old 02-23-2011, 11:26 AM   #8
remist17
remist17's Avatar
The light flashes but just the reverse light
Support the Troops.
Old 02-23-2011, 11:44 AM   #9
dropd80s
dropd80s's Avatar
If your taillight harness has been hacked this info is no good but the standard colors at your truck should be as follows.
Brown-----Tail Light
Yellow-----Left Turn/Brake
Dk Green---Right Turn/Brake
Lt Green---Reverse
Black------Ground
Your new lights more than likely grounded through the mounts but with out pics of what lights you have IDK. This will leave you with one wire being tail, one being turn/brake, and one being reverse.
If you have different colors you'll have to start some investigation with a test light.
dropd80s is offline   Reply With Quote
Old 02-25-2011, 01:03 PM   #10
remist17
remist17's Avatar
Lt Green---Reverse
Black------Ground
Would the single wire coming(green) out of the side of the bed below the two be the reverse light? I am assuming since I have no black that the original wires were grounded through the mount. Sorry to keep going around and aroung on this. Does anyone have photos of the correct stepside lighting?
Support the Troops.
Old 02-28-2011, 12:41 PM   #11
dropd80s
dropd80s's Avatar
I would guess so. Get a test light, put her in reverse and she if you have power.
