Old 02-20-2011, 03:21 AM   #1
sasquatch5308
sasquatch5308's Avatar
need help with my 250!
I just put a 250 in my 62 with some help from a few friends, we got it turning over but it wouldn't start. Replaced a bad fuel pump and I think its an electrical issue at this point. Does anyone have a wiring diagram that covers the secondary ignition? I've been trying to post pics on here for a while but I can't figure out how from my phone, and my computer crapped out. please help on both accounts! Thanks.
safety third!
1962 swb 4x4
1952 Chevy "turd bucket" truck
1953 Buick special
1953 Famous James motorcycle
1975 Scout II
sasquatch5308 is offline   Reply With Quote
Old 02-20-2011, 03:28 AM   #2
sasquatch5308
Re: need help with my 250!
safety third!
1962 swb 4x4
1953 Buick special
1975 Scout II
Old 02-20-2011, 08:45 AM   #3
finebammer
electronic ignition???
finebammer is offline   Reply With Quote
Old 02-20-2011, 12:40 PM   #4
sasquatch5308
No. It's got the old points setup. New plugs, wires, cap, rotor, and coil. Gapped the points. I'm not sure I have the coil hooked up correctly though.
safety third!
1962 swb 4x4
1953 Buick special
1975 Scout II
Old 02-20-2011, 12:58 PM   #5
Bugeyev8
Bugeyev8's Avatar
pretty simple positive is 12volt from ign switch and neg goes to the points, are you sure the points are set and clean?
Bugeyev8 is offline   Reply With Quote
Old 02-20-2011, 01:15 PM   #6
sasquatch5308
I cleaned the points with some sand paper and gapped them with a business card. I will check them again with a feeler gauge to be sure. Does the condeneser go to the neg side?
safety third!
1962 swb 4x4
1953 Buick special
1975 Scout II
Old 02-20-2011, 02:16 PM   #7
steve'62
steve'62's Avatar
how did you do the motor mounts? also what tranny are you using, i have a 62 and was thinking of dropping a 250 in
steve'62 is offline   Reply With Quote
Old 02-20-2011, 02:32 PM   #8
sasquatch5308
For the life of me I can't figure out how to post pics from my phone or I could show you, but I just made some from 3/8 plate and 1 1/2 inch 1/8 wall tube with some polyurethane bushings. Is your truck 4wd? If not you should be able to bolt up the later model perches that go from the frame rails to the sub-frame. You might need a spacer to accommodate the shorter frame rail.
safety third!
1962 swb 4x4
1953 Buick special
1975 Scout II
Old 02-20-2011, 02:41 PM   #9
steve'62
steve'62's Avatar
I am a newbie on here so I havent posted pics yet either! Its a 1/2 ton 2wd, w/ a 4 speed, 235 right now. buddy of mine has a rebuilt 250,also the bellhousing looks a little different. If you figure out how to post pics I'd love to see
Old 02-20-2011, 02:54 PM   #10
sasquatch5308
I'm also using the original 4 sp top loader but you need to find a small block bellhousing. Do you have the hydraulic clutch?
safety third!
1962 swb 4x4
1953 Buick special
1975 Scout II
Old 02-20-2011, 06:07 PM   #11
steve'62
steve'62's Avatar
Seems like those bellhousings are getting harder to find, and yes hydraulic clutch. plus there is few other issues like the water inlet, throttle linkage not bolting up to the block, i think a couple other things too, what other issues did you run into?
Old 02-20-2011, 07:58 PM   #12
sasquatch5308
safety third!
1962 swb 4x4
1953 Buick special
1975 Scout II
Old 02-21-2011, 06:40 PM   #13
sasquatch5308
So it still won't start. I've got power at the points, but no spark. New cap, rotor, points, condenser, coil, plugs, wires..... did the static timing to set the distributor, but even if it were off I should have spark right? Racking my brain!
safety third!
1962 swb 4x4
1953 Buick special
1975 Scout II
Old 02-21-2011, 08:24 PM   #14
rendus
rendus's Avatar
Did you do like I did a 100 times...leave the rotor on top of the heater box?
rendus is offline   Reply With Quote
Old 02-22-2011, 02:04 PM   #15
sasquatch5308
Haha! No but I wish it was something like that. I'm going to recheck my grounds today and try again.
safety third!
1962 swb 4x4
1953 Buick special
1975 Scout II
Old 02-23-2011, 11:40 AM   #16
sasquatch5308
[size=1]Posted via Mobile Device[/size[][/B]]still no spark. Checked my ground. Does anyone have a wiring diagram for this ignition? Just want to make sure I'm doing everything right.
safety third!
1962 swb 4x4
1953 Buick special
1975 Scout II
Old 02-23-2011, 03:03 PM   #17
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: need help with my 250!
Maybe these are the similar sasquatch5308.
I scanned these for an Ole' Boy once from my book:
1960-1961 Wiring Diagram
http://cid-9169aad55cfc6d79.photos.l...ring%20Diagram
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-24-2011, 03:53 AM   #18
sasquatch5308
Bad power wire from ignition to coil. Fired right up! Thanks everyone.
safety third!
1962 swb 4x4
1953 Buick special
1975 Scout II
