Old 07-07-2003, 09:36 PM   #1
Woodtop255
Unhappy temp gauge problem
the temp gauge in my 70 cst must be shorting out or something. it's pegged hot, even after I installed a new sending unit and a new gauge. does anyone know where each of the four posts on the back of the gauge lead to? It would probably work if I could bypass the printed circuit. any help would be greatly appreciated!
Woodtop255 is offline   Reply With Quote
Old 07-07-2003, 11:31 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The green wire that is on the sending unit...trace it back to teh firewall. See if it is melted on the manifold or something like that.
Old 07-08-2003, 12:31 AM   #3
mtdave2
newly minted old timer
mtdave2's Avatar
im dealing with the same problem right now. havent had any time to work on it.....let me know if you find anything.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 07-08-2003, 03:50 PM   #4
Blue68
Blue68's Avatar
I vote for a burnt wire. Happend to me as well. Manifolds get pretty hot. If the wire is good, unplug it from the sensor and it should go back to cold, then your sensor is bad. Otherwise, grab your schamatic and start tracing it throught the bulkhead connector because you've got a short somewhere. The printed circuits are easiest to look at with the dash out, that is once you figure out which wire on the connector is the one you want.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
