Old 02-24-2011, 11:10 AM   #1
1972K20
1972K20's Avatar
Positive Traction vs. No Spin Rear Axle
What's the difference between these two options? Is it basically just terminology? I've seen both listed as options for our trucks.
1972K20 is offline   Reply With Quote
Old 02-24-2011, 01:35 PM   #2
Re: Positive Traction vs. No Spin Rear Axle
You will find positive traction in 1/2t and Dana60 3/4t trucks and No-Spin only in 3/4t & 1t trucks with the corporate rear (HO52 & HO72 respectively). The posi in Dana60s is called Power-Loc,not sure about 1/2t but I think just Posi-Traction. The way they work is the second wheel engages when the first wheel starts to slip,giving traction to both wheels. the No-Spin is a locker,which means both wheels are engaged all the time. These are actually Detroit Lockers,which you may have heard of.
Old 02-24-2011, 01:45 PM   #3
CSGAS
optomistic ah-so
CSGAS's Avatar
"Posi-Traction" is actually a trademarked name for the particular method GM used in offering anti-wheel spin technology. Like Special-K said, it and the others engages the second axle and wheel when the first looses traction.
GM's particular design involves flat clutch packs. Others use cone-shaped clutches, helical-engaged gears, and a variety of technologies. Each one used a different name along with their particular patent, and sometimes are only different enough to earn a separate patent (which enabled one maker to avoid paying license fees to another maker).
I actually didn't know "No-Spin" was a Detroit locker installation...nice.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 02-24-2011, 05:16 PM   #4
1972K20
1972K20's Avatar
Great info, thanks!
